I Need Opinons Please
mikewood31
Guys long story short
3 years ago the wife bought a jeep Grande cherokee
because we needed a 4 door for the kids and 4x4 and it was pretty cheap
she wasn't working at the time so I figured I could get it road worthy
it needed work I never realized how much until I actually got into it........
..like every working part on it needed to be replaced and anything that held fluid leaked took me a while but I got all that fixed up and shes been driving it
the doors were always a bit saggy until the drivers door flew open on here once
the door latch basically tore right out of the metal ,so I welded that up
it is so thin the metal they used on these doors .032 or something any way
now the actual hinge has torn out bottom drivers side door so I took the door off
welded the hinge back on of course it broke again since the door weighs 75 pounds
the metal that the hinges attach to is thinner than a beer can its a joke!!!
okay so we take it to a body shop they want 3K and will not guarntee it won't happen again within six months even on the new door.Fine so I go to Chryslers body shop they tell me the same thing 3000.00 plus, new door paint all that won't guarentee it either
because they still haven't changed the door metal
So in other words srcap the vehicle because we can make an F.... door that will stay on it ,even though we know and have a TSB on the problem and lots of people have this problem on the gc and the cherokee model.
Im sorry this thing is not worth 3k infact Im going to tow it over to the dealer
with my Real TRuck both doors off it and put it on the lawn right buy the brand new ones it is a safety issue Dodge has known about it for years and has done nothing
So anyone that buys one of these better keep all their beer cans and duct tape
you'll need it.
my first and last dodge product
the wifes getting a blazer or jimmy soon as I can find her one
sell it to an off-road enthusiast, they can rig it up as a trail machine where doors wouldn't be needed anyway.
at this point thats probably all its good for. put it on craigslist as an offroad jeep or something
what year and motor GC?
if it's 1999 - 2005 with the 4.0L motor then the door is only one of many problems you will encounter..
the 4.0L had a known issue of "flattening" the cam. basically the cam wears to the point where it can't raise and lower the valves and you will end up with multiple cylinder mis-fires, and no power..
about $2400 to rebuild the motor (minimum) at that point.
oh yeah and I am and ASE Certified Chrysler Tech... though now I am no longer working for them since the BK filing.. I have a real job now..
well thanks man for the warning its a 95 Lerado 4.0
it ticks clunks, eats oil mostly into the air cleaner until I figured out
the PCV system LOL
but I didn't think the doors would force me to junk it
I thought the engine would go first
the PCV system LOL
while 1999 - 2005 are the offical vehicles with the problem, my EX had a 1994 Cherokee with the 4.0L that had the same issue, but it was not included in the TSB.. so take that for what it's worth..
thanks for all the reponses everyone
as always you guys help alot
Im off to the welding shop because I have to make this thing last
somehow through this crappy weather and then this P.O.S. will be gone
or as soon as I can find a 4.3 litre vortec with a transfer case attached that needs a good home :chevy: she will be alot better off.
The Inline 6 4.0 will outlast any 4.3L V-6 of GMs. That being said, the engine is the only good thing on Jeeps after Chrysler purchased AMC.
I've had an 89 Cherokee Sport with the 4.0, 5-speed, was ROCK solid, never let me down and to this date, was the best 4WD vehicle I've driven in the snow, with stock tires too.
I've had an 89 Wrangler with the Inline 4.3L I-6 (Carbed) Engine was great, carb sucked. Had 189,000 miles and still did awesome, despite some alternator issues.
And I've had a 94 Grand Cherokee Limited. 5.2L Dodge V-8. Loved the power, hated the AWD. AWD SUCKS on Jeeps. Even with great A/T tires.
Everything leaked on that thing too, even after $1300 worth of repairs to stop the fluid leaks, it still leaked. That ticked me off enough to finally sell her with 140,000 miles.
I'd take a pre 97 Cherokee 4X4 in a heartbeat. Same with the older style Wranglers, before they got the round headlights and the Crappy Chrysler makeover that made it not be a Jeep anymore.
well thats why I restored this one I heard the 4.0 was ......a good engine
this one ticks like a clock when it not spewing oil into the air box.
what pisses me off is I fixed all the leaks and window motors and
exhaust manifold crack and new front drive shaft,and crappy track bar bushings
and tranny cooler line leak and rear wiper motor ,PCV tubes,blend door motor
waterpump,brakes,new speedometer cluster,speed sensor,converter,muffler
tail pipe and tires ,found the short to ground killing the battery,fixed
the oil filter adapter leak,fixed the DRL module before it burnt up the thing
I even fixed the shitty remote that you have to be standing on top of it to use and now the f....... doors are falling off and can't be fixed properly
all this I did myself except took it in for an alignment
I guess Im just used to a higher standard owning about 5 gm trucks
3 of them 4x4's now, I never had 1/4 of the problems this thing has had
and now its scrap because its unsafe by vehicle standards
by rights if I took it to a shop they are supposed to keep it until I pay for the repairs
its deemed unsafe to drive.
Sorry to hear all the problems, hope you get them worked out. Wife had an '03 with the inline 6, not one single problem in 140k.....should have kept the thing, only 2wd though.
    • Can anyone explain why the oil pressure runs higher after the DFM is shut off?  just installed the Pulsar Lt.
    • Thanks!  I figured as such; GM and other manufacturers have used standard parts and harnesses across trim levels and such for decades.  I pulled the blank accessory cover off of my commuter van (a 2016 or so Chevy 15-passenger) years ago and found the plug for a USB outlet.  It wasn't connected to anything, though (I tried swapping in an outlet from another van).  I was a GM Tech years ago (late-90s) and was pretty familiar with my 2006.  I might be wrong, but I view newer vehicles (pretty much anything made in the past 20 years) as being a lot more plug and play.  Meaning, more unused wires and plugs unless you have the Mack Daddy of vehicles.
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
