Beer
drockZ71
miller high life, budwieser(diesel),guiness,harp,bass,modello,corona,killian irish red,almost any new glarus beer...i'm into most light beers, i want my beer to have taste
Molson, which is Canada's first beer dating back to 1792... My favorite saying they use is "an honest brew makes it's own friends".. And its true.. Carling is also good, cheap but good... I live on the USA border and when is the USA I like Bud and Rolling Rock.. Sam Adams is good too....
I have quite a few that I like. Favorite? Can't really say.
Yuengling - Black and Tan
Sam Adams - Haven't found one I didn't like!
Arogant Bastard Ale - Nuff said! LOL
I also live near a BJ's Brewhouse and I haven't found a beer there I didn't like.
I tend to stay away from the light beers.
Bud select, Killians, Dos Equis
Beer all tastes the same to me, but maybe thats because I'm young and drink to much at one time to really recognize the taste. With that being said, i like the cheapest beer you can get...either Busch light or natty light
i live in the state of brewerys and DUIs, and was born and raised in the city of beers..and the tahoe lol
    rayredbone
    rayredbone
  • Who's Online   3 Members, 0 Anonymous, 304 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
