Hid Install Help
I have a 2005 GMC Sierra an I bought a HID kit for the low beams its simple plug and play so they said... When i plug everything up it doesnt work. The only time they do turn on is when I hold the high beams on as in pulling the lever toward me but they dont when you push the lever back to keep the high beam on (their plugged into the low beam but only work on highs!?). Many people have told me i dont need a relay harness for this truck. Ive tried pulling the DRL fuse an nothing. Basically when i put the factory lights back in everything works normal again when hids are plugged in to the low beams the low beams only work when you hold the high beam lever forward. How and what do I need to do to install these and make it work because im really lost on why its working like this.
What brand of kit did you buy? Also I would highly reccomend using a relay harness, it may be a little more work, but it causes much less strain on the headlight circuit.
As for your specific issue. I'd do some searching and look over all your connections and the directions again, it sounds like you may have a signal wire mixed up somewhere
Its Truss and i checked and re checked all the connections just to get it to work the way i did I had to reverse the polarity
I did my 04 last year and had to reverse the pos./neg. with the extra wire connector they gave me and no problems,maybe you got a defective unit....mine was a PROMAX $60 kit from Amazon
    • Hey everyone,   For anyone looking at roof-mounted lighting for the Hummer EV, we wanted to share our M&R Automotive 50" PRO Roof Light Bar for the 2022+ GMC Hummer EV.   The curved 50" bar sits close to the windshield rather than sticking way up above the roofline. The mounting position is designed to keep the setup relatively streamlined while minimizing wind noise and maintaining full use of the factory windshield wipers.   A few details:   50" curved PRO light bar Fits 2022–2026 GMC Hummer EV Spot + driving beam pattern TIR optics White main beam Amber DRL backglow Approximately 15,410 measured lumens through the lens Mounts to factory accessory locations No cutting or drilling required Wiring runs down the A-pillar toward the AUX connections Designed to minimize wind noise Lifetime warranty Off-road use only     The 50" is an interesting middle ground for anyone who wants the visibility and mounting position of a roof bar without stepping all the way up to the larger 60" setup. For the Hummer EV owners here, would you go with the 50" for the lower-profile look or step up to the full 60"?
    • My son got a hatchback withe the aero package for like 17k new. Great little car with amazing MPH
    • Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".   ONE MB??? That's Windows 95 ******, lol!!
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.   Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS   Seems like that site went back to dial-up internet! Maybe they'll fix that some day ...
