Maggie And Afm
How well will a Magnacharger work with AFM or will it? I suppose it could be disabled in with a Tune but would it work?
Sure it will...The tune (that will be required with a Maggie anyway) can disable it.
However...AFM only comes on at lower RPM's with a low throttle position (very light loads) ...And the Maggie has a bypass valve that keeps you out of boost under the same conditions. Hell...You may not have to disable it.
/just thinking out loud, don't know if they play well together and I've never done an install on an AFM equipped vehicle, so I'm talking out of my ass :lol:
It is not ideal, just need to have it tuned out.
Figured that was the answer.
<<<Contemplating a maggie for the Avy...Just because :thumbs:
IMO, If you can afford the Maggie and want to do it right, spend the extra $$ and time and replace the AFM lifters with a set of LS7's and do away with AFM by tuning and the heavy complicated AFM lifters that can fail on stock applications. With the LS7's you get a more durable lifter and a much lighter weight lifter compared to the heavy AFM lifters. Might as well throw in a small blower cam while you are in there, along with stronger valvesprings. Your 5.3L #243 or #799 casting heads are allready awesome from the factory in terms of flow to support a modified 5.3L.
