Lube Job On 2009 Silverado Cc Z71
Did some maintenance on my pickup over the holiday weekend. Owner's manual says to lube front suspension, steering linkage, and parking brake cable guides, and it also says control arm ball joints on 1500 series are maintenance-free (factory sealed, no grease zerks). I only found 2 grease zerks (on top of tie rod ends), but where I was it was hard to get under there and see everything. Seems kinda funny the General would put it only 2 grease zerks; guess I would've expected either all points or no points to have grease zerks.
Did I miss any other grease zerks on the suspension, steering, or u-joints?
Thanks in advance for any replies!
I know I can't wait to replace the factory sealed units with stuff thats serviceable! I hate that self maintenance is not taken into consideration when cars/trucks are built anymore. Just like mentioned in another thread, there isn't even a dang underhood light! Has anyone ever tried to use the factory emergency jack in a red cab pickup? Its a royal PITA to just get out from behind the seats; you have to almost be a regular contortionist!
I just carry around fix-a-flat. But, I still miss the retractable under hood unit found on gmt-400s.
While I do agree with you about the lack of serviceability on newer vehicles I will say that a lot of the stuff that use to be maintenance things last longer when they aren't greasable. Case in point, my 98 K1500 has the original u-joints in it with nearly 200k miles on them. Find a greaseable joint that will last that long. It won't because water and dirt will be getting in, more than you can flush out. Just sayin. :thumbs:
I still have mine, and it works. :D
Get you a 12-volt flourscent or LED work light with a 25-foot cord. With one of these, you will have enough light to perform your maintenance in the dark.
    • Hi, New here.  2026 Denali HD.  Just purchased 7/2/26. I am having the same issue.  I just traded in my 2024 AT4, and the truck connected to bluetooth and Android Auto Immediately!  Now, with the new HD, it connects when it wants to, which is usually not at all.  I have to use the usb-c cable to get it to connect.  Bluetooth won't even connect without the AA. Now after saying all that, I'll take a 20 min drive with the phone plugged in.  Stop at a store, restaurant, etc....  Get back in my truck and DO NOT plug the phone in.  The truck then decides at this point, lets connect BT & AA and work perfectly, ie how it should.   I have deleted (forget phone) the phone multiple times.  I guess I'll just get used to plugging it in every time. even though I don't think its good for the phone battery to have it on charge after it hits 100%. I have searched all over.  No one else seemed to be having this issue, until I read this thread today.   thanks for reading.
    • I have an issue with my ignition hanging and I have to tilt the steering wheel to get in the off position. I have used a great key lock spray and it doesn't help resolve the issue. Is this an ignition assembly issue or something else. If anyone has a past experience with this please advise.   Thanks  Heath
    • This is a terrible GM warranty experience, two months waiting for a covered engine swap with no loaner or timeline is not allowed under GM’s courtesy transport policy.Escalate straight past regular support to a GM executive case manager, document every closed service ticket and dealer repair paperwork. File a complaint with NHTSA to force faster action, and ask for daily rental reimbursement while your truck is down. If it’s been out of service over 30 days, your state lemon law may let you pursue a full vehicle buyback.
    • 198°F isn't unusually hot for an 8L90, so I don't think temperature alone caused the issue. Since everything returned to normal after the truck sat for several days, I'd be looking at an intermittent electronic or hydraulic control problem before assuming the transmission itself has failed. The first thing I'd do is scan the Transmission Control Module (TCM), not just the ECM. GM transmissions can store manufacturer-specific or history codes that won't trigger a check engine light. I'd check: TCM history and pending DTCs Commanded vs. actual gear Line pressure Shift solenoid status Torque converter clutch (TCC) slip Transmission fluid temperature If it happens again, try to capture the data before cycling the ignition, since some intermittent faults disappear after a restart. A professional scan tool that supports full GM transmission diagnostics makes this much easier. For example, the Foxwell NT809BT can access the TCM, read manufacturer-specific transmission codes, and display live transmission data that's not available on a basic OBD-II reader: https://www.foxwelldiag.com/products/foxwell-nt809bt Hopefully it's just an intermittent control issue, but I'd definitely pull the TCM data before replacing any parts.
    • Sorry, I accidentally posted in the wrong language. I'll repost it in English.
