Too Many Lifts To Choose From
I have a 2010 silverado 1500 Z71. For some reason it feels like a low rider.I was looking at the rc 3 inch with control arms. I read alot of bad things about the lift, but for the price it seems right. I was wandering if i should go bigger and not worry about the gas mileage. 33 inch with the 3 inch or 35 inch with 7.5 inch please help me
Go BIG or Go Home :cheers:
If you are even considering the 35's then get the bigger lift the first time. If you get a smaller lift then decide you want bigger tires..you'll be pissed you got the smaller lift.
Plus you can always run 33's with the bigger lift and be fine as long as there wide 33's IMO.
Don't forget about possible gear swap if you go with 35's depending on what gears and trans you have now.
I don't think you'll get much support for the RC 3". I believe that is the kit most here have had problems with but I'm not 100%.
