Remote Start
I have a 2011 with code AUO so I don't have the Remote starter prep. I asked them to order the 2 way remote start that I read on GMPD can work with AUO. They ordered the standard system instead and told me none of the GM systems work with AUO. are they lying or do I have to go aftermarket? thanks
The only remote start that I see listed for the 2011 is the standard one that you must have RPO of AP8 for. GM has also temporarily stopped installing these in the 2011 because of a programming issue.
I would just go aftermarket alarm with RS. I mean from what I have read AUO is for the key less entry. Maybe I am wrong but either way... aftermarket
I did a little checking....they do list a GM 2-way remote start system with code AU0,But not for the 2011 model-year as of yet.
I agree on aftermarket. but be warned that some of those businesses have worthless employess. only use a good reputable place thats been in business for a long time. ive been fighting the place that installed mine for a while now and i still dont have reverse lights cause of them and the mess of wires they left under the dash.
perfect. just the info i was looking for. If they tell me exactly this fine. If they lie to me we've opened a whole new can of worms lol. I gave them that PN and told them to check it out. If they don't list the 11 fine but they can't tell me it isn't listed for 07-10 like I said
thanks.
IF I do go aftermarket I'll only be using a good shop. I wanted the GM one because of the wire hack jobs I have seen but I will just be picky if I have to go that way
Viper (made by DEI) has a full interface module available which will require minimal wiring and will work and have the heated seats and defrost too
they are ordering the 2 way ARSS for me. they say it will work on 2011s so stay tuned......
Let us know Mike,I just got off the phone with our GM-ADI here and found out they finally released the reprogram codes for the 2011's for the regular remote start system,But I didn't ask them about the 2-way advanced system.
I will... I had to push to get them to even get this for me because the parts guys didn't want to research it. they ordered the basic kit for me when I said specifically the 2 way, and wasted an hour of the tech's time and mine while he tried to get it working
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
