Steering Linkage
kmborland
hey guz,
i have a problem with trying to remove my inner tie rod ends from the center link. is there a special tool or a special way to remove the tie rod from the center link? my truck is a 95 2500ld 4x4 that has a 4" trailmaster lift.
Thanks for the help,
Kirk Borland
Either get yourself a small pickle fork (but that will damage the boot -- won't matter if they're getting replaced), or THIS
The one still in the case in the picture is what you need.
Thank you, what is the one in the case called? can i just get that tool by itself or be able to rent it from auto zone?
i have been trying with the pickle fork method with no successful outcome and i was wondering if there is a special way to remove the inner tie rod from the center link? like, do i have to place the pickle fork a certain way or something of that nature? bc no matter what i do with the pickle fork and pb blaster, its not giving.
Usually you have to hit them pretty good with a heavy hammer, especially if you live in the northern part of the country -- the salt rusts them so bad that they're just about welded together. If your not going to be re-using the part, a LITTLE heat helps ... just don't go overboard on such a critical part. And be aware that the boot & grease will catch fire - so use common sense there.
Also make sure the pickle fork is the correct size ( not too wide ).
That tool I guess is just called a Tie-Rod End Remover tool. I've had to crank on those pretty good with an impact gun, then whack it sharply with a hammer. They can be stubborn sometimes. Keep at it and I'm sure you'll get it eventually. It's never easy ...
Thanks again, i will try the tie rod tool the puller tool tomorrow or Tuesday. if those dont work then i guess i will try some heat.
you dont ever use heat on steering ,NEVER !!!!!
air chisel with u-joint insert shocks the tie rod and it falls apart,take the nut off and bark the tie rod end stud (only if replacing the TRE)
Might not be the proper way, but I've done it for 30 years. Going by the way they make sheetmetal these days, I'd have to believe you. Advice retracted. :thumbs:
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
