Mterodome Collapse
wurgs
The Metrodome in Minneapolis collapsed at 5:30 this moring. They had 18" of snow during the storm and the roof couldn't handle the weight. Todays game is to be played tomorrow in Detroit. I already have tickets and hotel for next weeks MNF game against the Bears so hope they can fix it quickly, otherwise out about $500.
I am not an engineer by any means but wouldn't the heat from the building just keep the roof warm enough to melt the snow as it is falling? And if the snow was coming down too fast for it to be melted by said heat then who came up with the brainy idea to build a stadium with an inflatable roof in one of the snowiest regions of the country?
Yea. Seems like kind of a strange design but has only collapse once before and only took 4 days to fix. I believe the roof is made of some kind of teflon fabric and has a pretty good slope on it so snow seems to not typically collect on the roof. They don't usually get that much snow at one time, it was said to be the worst storm down there in 20 years.
With it being inflatable I'd assume it would have 2 sides and have a pocket of air with the bottom acting as a shield. So Maybe all the heat wasn't getting all the way to the top layer? :thumbs:
Anybody notice the audible POOF when all the snow hit the field? I think that's the most amazing part of it. Hate to think what the outcome would've been had this happened during the game. :thumbs:
It would have been awesome if the snow dumped right on Bret Favres head. Let's see if he can get up from that one....
I was wondering why don't they have a heating element in the roof to melt snow when it falls. You would think they would plan for a getting a lot of snow.
The roof has 2 layers and they were blowing hot air in between to try to melt the snow but it could't keep up. Maybe this is what it takes to get the Vikes a new stadium. The Metrodome is about at the end of its usefullness.
Or at least a new roof, which is probably why they did not take drastic measures to try and melt the snow off.... Because their insurance is going to buy them a new one....
    ncleg
    ncleg
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
