MudderZ71 Posted December 19, 2010 Posted December 19, 2010 Im having some troubles figuring out what size tires my truck will take. I just put a 3" leveling kit in the front and a 2" in the back on my 09 Silverado Z71. I have aftermarket 20" rims, I want to put bigger mud tires on, I Just dont know what size before I start rubbing....any suggestions?
SouthCo Posted December 19, 2010 Posted December 19, 2010 Don't know for sure, depends on offset. Stock ride height and stock oem 20" fit a 32" tire. So you should clear a 33" with no problem. Not sure about anything taller. width would depend on offset of your rim.
MudderZ71 Posted December 19, 2010 Author Posted December 19, 2010 Don't know for sure, depends on offset. Stock ride height and stock oem 20" fit a 32" tire. So you should clear a 33" with no problem. Not sure about anything taller. width would depend on offset of your rim. Awesome Thanks! Ill Try the 33's and see how they fit....
