Traction Control And Stabilitrak
My direct answer to the OP is this: if you have to ask, you should probably just leave them alone. If you aren't sure exactly what each does, and/or how to drive with them on or off, you should just leave them on.
Personally, I can drive a rig like this with TC and ST just fine (of course) but will become annoyed with it, especially on any kind of slick roads. I prefer not to use them on slick roads. That's because I know how to handle a rig, make it do what I want, and correct any over/understeer and slides. I grew up driving a '75 Ford F250 with good old fashioned four wheel drive on snow.
If you don't know how to handle a rig on your own in situations like this, and you aren't sure of what the TC/ST settings do, you probably shouldn't mess with them. Just please move over so I can pass you when it's snowing ;)
NO VALUE ADDED
  • 3 years later...
so here is a senero that happened to me last year
driving an o3 yukon awd t/c and s/t were not working, abs was (i think)
i was driving at about 60-80 kph on a wet icy road (during an ice storm)
at the last moment i saw an obsticle in the middle of the road (n my lanes)
i hammered the brakes, the truck started to slide sideways (pointing towards the centre of the road)
i let off the brakes and drove around the obsticle
now if i had the t/c and s/t working, what would have happened ?
