Lift Kits And Warranty
I am sure this has been asked before, but I will ask again :D
For those with new trucks and the 100k powertrain warranty, does'nt having a lift kit void the GM warranty in some way?
I cant help but think if anything ever went wrong with engine or transmission or front end components, there would be no way to get it covered under warranty with a lift kit installed.
Although, I have seen some dealers sell new lifted trucks, assuming with full dealer warranty.
Would like to maybe get a lift, but not taking any chances in voiding my warranty.
Thanks for any help.
Mike
They would have to prove the lift caused the part in question to fail. So engine or tranny problems shouldn't be traced back to a lift. Now driveshafts and front half shafts/cv joints may be a different story.
When you lift a vehicle you have killed the warranty on parts replaced by the lift kit and you open a can of worms as far as future warranty work. You are really at the mercy of the warranty service writer and his GM district rep. If you have transmission trouble down the road they can potentially say the added stress of accelerating harder from the lift kit caused the tranny more stress. While it might be a totally BS, they will stand behind it. I would talk to your local service dept and see what their policy is before lifting.
I had a Jeep dealer tell me my starter was not under warranty on my lifted TJ because I offroaded and it was exposed to unusual elements. Also that my OEM seat material was not under warranty for tearing at 15K miles because I had a lift and I had to slide over it more.
you just have to be ready to stand tall and make one hell of a scene and yell at everyone and their mother. added stress on tranny from taking off. yes i see it. no question about it. however trucks are meant to tow. so if you towed every day what would the difference be? be ready to fight tooth and nail. HOWEVER get a quality lift kit (bds has an awesome warrenty) and get new gears installed (to bring back performance/make it easier on the transmission) youll never have an issue aside from normal wear and tear. you might just notice things like tie rod ends wear out a few thousand miles sooner. and brakes dont last as long.
    • I have a 2018 Silverado Custom with 156k on the odometer. In the last month I've replaced the plugs, wires and the driver side engine mount. My wife just returned from a trip of about 1500 miles and told me the brakes are making a grinding noise when applied. I drove it and looked it over and this is what I found with the driver's side rear rotor.   I'm going to order new pads and check about having the rotor resurfaced. Hopefully this is easier than the last 2 jobs.   Peace
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
