Drop In Filter K & N
Kon Man
I have a 3000 mile old K&N drop in filter for my 2009 Sierra 5.3L. Should fit most of the GMT-900 5.3L. I will clean and oil and put in a zip-lock bag in the original box and ship to your doorstep.
Part number is 33-2129. Check you fitment at www.knfilters.com
How about $30 + S/H
Email is best [email protected]
Thanks for looking.
45 views and no takers.......Somebody needs to change their paper element out now. Might as well get one that will outlast your truck!!!!! :D
Help a brutha out here!!
Really? You can buy then new at amazon for $38 with free shipping
A used filter is worthess imo
K&N 33-2129 Replacement Air Filter by K&N
List Price: $64.97
Price: $38.66 & this item ships for FREE with Super Saver Shipping.
Thank you Amazon hall monitor, for your worthless opinion.
In light of this wonderful comparative shopping analysis, I guess I'll be open to reasonable offers.
Oops. Double post. I also didn't mean to sound terse. I would have appreciated that kind of input too.
Larry
Larry
Yeah Larry, it sounded like he was trying to help by telling me my stuff is worthless.........thanks for your input also........
:wtf:
Instead of that smiley, i should have done a :P since this thread is full of win :wtf:
Goodluck with your sale but when posting on a public forum for all to see, and all to respond, you should realize that if your deal isnt screamin on a used filter, you will get some criticism.... If someone buys something off the internet its mainly to save $ and usually one of the first places to go is amazon or ebay... At least i do.. And when i list stuff on forums, i check such sites first to see what there price is since whats the purpose of buying something off an individual when a company has cheaper.. Gives you a good guideline of where to start your pricing.
One other thing... and please take this as constructive criticism, I dont know if i would choose a username as "Kon man" when trying to sell something :dunno:
:thumbs:
Yeah, but some of us don't sit on internet forums all day, or research prices of stuff on ebay all day. I don't touch Amazon EVER, so I don't care what they say. If you aren't interested don't look, nor is it a requirement to respond to every f'ing post you read. There are people on here selling used crap at rediculous prices all the time, but I don't feel it necessary to belittle people for it, I simple go to the next thread.
And the name "Kon Man" came from the first GM vehicle I had when I registered on most of these forums, which was a YUKON, hence the name.
I may take it off your hands, if it fits in my truck. I have the 6.0. Where in SE MN are you. I live in Zumbrota, but am in Roch damn near every day. oh, and why are you getting rid of it
List Price: $64.97
+1 used air filters
Looks like he is in SE NM buddy.
    • Engine failure requires radiator replacement per GM if it contains an engine oil cooler.  They do NOT want them flushed.  Radiator replacement is also required for the 6.2 recall if the engine fails.   Here is the TSB the dealer is referring to - 22-NA-074 1..2    Its a slightly older version, but the current version of it covers all model years 2000-2026.  So if enough failure debris was present, it gets an oil cooler.  If that is part of the radiator, it gets a radiator.  Also, same for oil cooler lines.  Those get replaced.     Now something like a 2.7 Turbo which uses an oil to water heat exchanger for the oil cooler, the radiator would be left alone but the oil cooler would be replaced, as well as any lines.
    • Doing the right thing, replacing both valves is the way to go. The valves with the ball leak far more often than the schrader. Never cared for them. The accumulator really should be replaced if the system has had no pressure in it and it was a keeper, but since you're looking to sell it, bet you can get by. Did you pull the orifice screen and see what was there?   Shame you can't get 134a. Hopefully the previous repairs included dye.   Some of the R4s I messed with developed leaks where the line sets connected or the front seal. Had one where the HPCO was leaking. Front seal would only leak under pressure. See any obvious oily spots?   I've got nitrogen I use to test pressure and to help dry the system prior to evacuation.   Keep up the good work
    • Next time you're on a road trip to a state where you can still buy it stock up on 12oz cans, you might look into getting certified so you can buy it where you are as well. When they switched from R12 to R134a the test for certification was easy, they basically just wanted the $25
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
