Fuse Block Left Side Of Dash
cjobrien1972
I have a 2004 Silverado LLY. The fuse block on the driver side under the plastic panel is the area I need help in.
On the fuse block in the lower left corner there are 5 pins not in use from the factory. Two are in one column, then beside them are 3 in another column.
I used the two bottom pins in the row of three to supply power to some accessories. The bottom two are switched with the ignition and the top one is constant. It has been wired like this for years.
Recently I had the power stop working on the middle pin. I assume there is a fuse somewhere that supplies power to this pin. I can not find it?
Can anyone help me find where the power comes from and the fuse that supports it. I assume it ties into the panel near the drivers foot, but I still can't find the fuse link.
And yes, if I move me connection to the constant power, my accessory turns on. Basically the middle pin is dead for some reason?
Not sure what the pins are, but have you checked the fuses under the hood? There has to be a fuse somewhere for that circuit.
Yea, I checked the one under the hood too and could not locate a bad fuse. If you pop that plastic panel off on the driver side and look down toward the bottom of the fuse block, you will see an open area with 5 total male pins for a female plug sticking out. (2 go together, then beside it are a cloum of 3).
Based on the pic of your maroon truck its the same design as mine. If you open that panel you will see. I have a picture, but I can't get it to post. Do I need to put the pic on the web? Can I send it to you in e-mail format?
Connector Part Information
• 15401495
• 48-Way M Metri-Pack 280 Series (BLK)
Pin Wire Color Circuit No. Function
2A DK GRN 117 Right Front Speaker Output (-) (UQ3/UQ5)
DK GRN
117
Right Front Speaker Output (-) (UQ7/Y91)
2B
LT GRN
200
Right Front Speaker Output (+) (UQ3/UQ5)
LT GRN
200
Right Front Speaker Output (+) (UQ7/Y91)
2C
BLK
1851
Ground (AU3 w/o YE9)
2D
BRN/WHT
230
Instrument Panel Lamps Dimming Control (AU3 w/o YE9/Y91)
2E
TAN/WHT
746
Right Front Door Ajar Switch Signal (w/o YE9)
2F
BLK
1050
Ground
3A- 3F
Not Used
4A
BLK
1050
Ground
4B
ORN
52
Blower Motor High Control (C42 and CJ3)
GRY/BLK
2337
Lower Right Air Temperature Sensor Signal (CJ2)
4C
PPL
73
Medium 3 Blower Motor Control (C42 and CJ3)
BRN
718
Low Reference (CJ2)
4D
RED
542
Battery Positive Voltage
4E
TAN
63
Blower Motor Medium 1 Control (C42 and CJ3)
PPL
1838
Recirculation Door Position Signal (CJ2)
4F
PPL/WHT
760
Blower Motor Speed Control (CJ2)
4G
YEL
60
Blower Motor Low Control (C42/CJ3)
4H
Not Used
4J
LT BLU/BLK
1688
5-Volt Reference (CJ3/CJ2)
4K
LT BLU
72
Medium 2 Blower Motor Control (CJ3/C42)
4L
Not Used
4M
YEL
1791
Low Reference (CJ2/CJ3)
5A
Not Used
5B
LT GRN
2275
Mode Door Position Signal (CJ2/CJ3)
5C
TAN
2273
Mode Door Control (CJ2/CJ3)
5D
DK BLU
1199
Left Air Temperature Door Control (CJ2/CJ3)
5E
LT BLU
733
Left Air Temperature Door Position Signal (CJ2/CJ3)
5F
Not Used
6A
ORN
3840
Battery Positive Voltage (CF5)
6B
BRN
2409
Interior Park Lamps Supply Voltage
6C
BLK
1050
Ground
6D
DK BLU
1353
RAP Supply Voltage (CF5)
6E-6F
Not Used
7A
GRY
295
Door Lock Actuator Lock Control (AU3 w/o YE9)
7B
TAN
1047
PDM Class 2 Serial Data
7C
ORN
4240
Battery Positive Voltage (YE9)
7D
TAN
294
Door Lock Actuator Unlock Control (AU3 w/o YE9)
7E
WHT
194
Door Unlock Control (AU3 w/o YE9)
ORN
1340
7F
LT BLU
195
Door Lock Control (AU3 w/o YE9)
DK BLU
2115
Right Turn Signal Lamps Supply Voltage (Except Base)
8A
WHT/BLK
2339
Lower Left Air Temperature Sensor Signal (CJ2)
8B
Not Used
8C
BRN
341
Ignition 3 Voltage (CJ2/CJ3)
8D
DK BLU
1646
Right Air Temperature Door Position Signal (CJ2/CJ3)
8E
WHT/BLK
1236
Right Air Temperature Door Control (CJ2/CJ3)
8F
DK GRN
1614
Recirculation Door Control (CJ2/CJ3)
I believe you are talking about pins 3a-3f. I have searched functions for these pins and all I can find is " not used." It is possible the connection was lost inside the junction block. Best thing I can say at this point is to find another wire to use.
