Torque, Anybody?
General Lee 01
HOLY TORQUE BATMAN!!! i wanna know power numbers!
all i can tell you is that the numbers will be in the 4 digit zone.
if i could get half that toque out of my truck would be sweet, heck i would be happy with a quarter of that. :jester:
thats an event they have every year in Quebec
Where do I sign up to drive? Thats awesome!
where!?!?! I'm so going next year if its not too far of a drive!
Yet i get pulled over for having no cat on my truck because of global warming these 2 trucks probably just killed 3 polar bears.
My thoughts exactly. Haha
who cares.
who cares.
lol at the cat comment. and yeah, who cares when you can make 2000 ft/lb of tq!!!
