Rough Country 3" Kit
Rough Country 3" Kit, 20,000 Mile Update
Just thought I would give a Long Term Update on the Rough Country 3" Lift Kit.
There have been lots of negative results out there even before I purchased mine but I decided to go with it because it is the perfect lift hight and is easily returned to stock. I went with the optional control arm upgrade as well. Cost was good as well, I installed the kit myself.
So far I have had zero issues with the lift, no worn parts no drivability issues at all, the only downside is the rougher ride and MPG drop but both of those were expected and I blame most of the rough ride on the tires since I went with load range E tires. I am runnung 33" Firestone Destination MT's.
Would I recomend this lift to others, Yes, so far I have seen no reason not to.
By the way, the truck is a 2009 Silverado ECSB 4x4 Z71 with 3.73 gears and the 5.3L
Out of curiosity, did you notice a real difference with the LT/E tires when towing (stability)?
No not really but I had installed the lift at the same time the tires went on and I have never really towed anything really heavy with that truck (3500# and less).
On my 2008 I still have the stock Bridgestones that are P265/65R18 and tow my 8000lb Travel trailer, I have pulled that trailer across the country with no issues and that trailer has 1000 lbs of tongue weight. I do suspect that the heavier weight rated tires (Load Range D or E) would be a little less likely to sway but I am not sure if the harsh ride is worth it.
I've read "over again" on various forums that the LT tires at 60 psi significantly reduces "wabble" when towing. Haven't tried myself, but wonder. I do know that running max pressure in my P tires (44 psi) makes a *noticable* difference in "feel".
So your upper control arms don't touch your coils and your alignment is within specs? If that is the case, I think you are the ONLY one who is the exception. I'm so glad they bought that crap back from me.
It is good to hear you like it, I hope you don't have any problems with it. Truck looks good!
There are a few that Ive seen have no problems. I seen the re designed the upper a arm and balljoint.
i mean i was going to do the 1.24" BL so i might try it out! I really only just want to run a 33x12.5 untill its paid off. Then ill go crazy with it!
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
