Will This Work?
berteras
what will it take to get a 305/55/20 on a 20x9 rim with a +14mm offset on my truck, all I currently have is a level kit on the front? Im trying to decide if I should go with a 305/50/20 or the 305/55. my current tire is 32.6" tall and the 305/55 is 33.2" tall and I dont come close to rubbing right now.....the 305/55 would only be .3" more on each side to the tire but everyone says its gonna rub.
Would a zone 1.5" body lift be enough for them to clear??
Ok thanks!
its crazy that it takes a 3" body lift to fit an extra 3/10 of an inch taller tire.
It's not that they won't "fit" necessarily. What are you willing to do? Cut metal? And it also has alot to do with the width of the tire more so than the height alone. I would go with a 3" and be happier in the long run. Everyone ends up wanting more height in the end.
Im not opposed to cutting metal but if I could find a way around it than I would rather go that route. Im not sure if I want to go with a 3" lift. I may just get the 305/50/20 and be on the safe side
I highly recommend sticking wtih the 50 series the 55 series is way too much for 1.5" of lift, not only will it rub like crazy but it flat out looks too big on the truck compared to the amount of lift.. To really properly clear the 305/55/20 you should do a 2" level and a 3" body lift or a 4" suspension lift. Its just the way she goes.
ALSO regardless of the fitment and size issues, the truck will run better with the 305/50s vs the 55's. They are lighter tire with less overall diameter.. (can you get a 305/50 in D range rather than E range?? that would be alot easier on the truck.) To properly run the 305/55/20 not only should you run the bigger lift, but 4.10 gears as well.
edit: i have personally ran a set of 305/55/20s for 50,000 miles on an 08 silverado. with and without suspension lift.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
