U-joint Grease Fitting Problem
hey everyone how ya'll doing? well today i greased 11 zerk fittings in the front end. i went to the rear end to grease the u-joint fitting and the fitting on my gun will not go on. the fitting on my gun wont fit inbetween so i cant get it on the zerk fitting. i dont know if im doing something stupid and having a brain fart but i cant grease it. any ideas anyone? can you get a smaller fitting for your gun thats smaller in diameter? thanks again
Do only the 4wd trucks have U-joint grease fittings? I haven't seem any on my 2004 2wd Suburban but I did find all 11 on the front end suspension. I wish it did have U-joint grease fittings.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
