Spare Tire Cylinder Lock
2005 Suburban
The spare tire cylinder lock wont budge. Key wont even turn. Has anyone had this problem in the past and how did you get it out. Need to use the spare tire. I would rather not mess the lock up but if I have to I will. Anyway of taken it loose from underneath?
Thanks in advance for any help !
sorry I can't help you with a solution but that is why I pitched my lock as soon as I got the truck. Does anybody steal spares? Also, when I rotate my tires I use the spare as I move the tires and jack around. That way the spare lift gets a workout and I shoot it with a little lube at the same time. Nothing worse than being stuck on a snowy cold road and not being able to get the spare down.
Have you tried spraying something like WD-40 into the lock cylinder? There are also some specific fluids meant to free up lock mechanisms and they should be available at places like Home Depot, Lowes or even the local locksmith.
It does sound like the cylinder has frozen up. Once you get it freed up, use a graphite spray (dry graphite) to keep everything lubricated. Won't hurt to just unlock then lock cylinder every couple of months to keep it working.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
