Tonneau Cover
Will a cover from a 07 NBS short box extended cab with a box of 69.3 fit a current 2011 model. As far as i know the box on a crew cab is the same? Just looking for verification.
Thanks
Thanks
The box on a 1500 Crew is shorter than the box on an extended cab.
Thanks
True. Extended cab short box is around 6' and a crew cab short box is around 5'
in 2007 an extended cab short box was the same size bed as a crew cab short box. My question is has the box size changed on a crew cab? I don't believe it did but just want to make sure.
Extended cab short boxes aren't made anymore.
Specifications for 2007 trucks
The short box on my dad's '11 crew is the exact same as the short box on my '08 crew. You should have no problems.
Extended cab/short bed boxes are approx 6', Crew Cabs are 5.5' approx. Has been this way since they started making 1500 Crew Cabs. You can order an extended cab with the 8' bed. So, a tonneau cover for a 1500 extended cab WILL NOT fit a 1500 Crew Cab and vice versa.
the boxes are the same i sold it and it fit perfect. So for the record a short box extended cab is 69.5 inches the same as a crew cab!!!!
Not sure what you're comparing, 07 Crew bed to an '11 Crew bed? If so, then yes, beds are the same.
If you're comparing an extended cab bed to a crew bed, both on 1500's then no, they are not. The extended cab 1500's came with either a standard bed (78.7") or a long bed (97.8"). 1500 Crew cabs came with only the short bed (69.3"). You could get the standard bed on a 2500 Crew Cab, but the half tons just had the short box.
The extended cab did come in a short, standard, and long box. Extended cab with short box looks good, sport truck like.
Wow! You've got yourself what has to be a rare truck there! Was that a one year deal or very limited option? I'm pretty closely associated with a Chevy dealer and have never seen or heard of one of those. I also checked Chevy's website and that doesn't appear to be an option now, either. Makes me wonder more why they didn't also offer the standard bed on a crew cab. With the exception of the fact that my truck fits nicely in my garage, I HATE the shorty bed on my crew and miss the standard bed from my older extended cab.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
