BigZed Posted February 10, 2011 Posted February 10, 2011 Hey guys, Did a search but didn't find much info on the subject. Have a 2010 Sierra SLE 5.3L ext cab 4x4 and was wondering if it was viable to throw a conversion into it. My two main concerns are a) fuel efficiency b) performance. I know they can run around $5000 CDN to install but in the long run you'd get your money back so it's just a thought I'm starting to kick around. Also I tow a 18 foot open bow boat so curious as to how this will effect my towing (goes along with my performance concern). Thanks in advance
DwayneJ Posted February 10, 2011 Posted February 10, 2011 I knew propane contained fewer BTUs so I just did a google search and here was a quick large list of fuel BTU ratings. http://www.scribd.com/doc/29682681/Heating-Fuel-BTU-Values BTU is energy content so it gives a pretty good indication of what will get better and worse economy.
imollison Posted February 10, 2011 Posted February 10, 2011 Quite a few years ago (about 20 I think), the Canadian Forces changed over their entire bus fleet from gas to propane, claiming that they would be able to save a whole pile of money over gas. They also had lots of vans and some trucks that ran propane as well. The long and short of it is this: in the summer, in the flat parts of this great country, it worked well, could tow like gas, and did save some money. The problems are that it does not work well below -5 degrees C, it really hates having to work at altitudes like Alberta/ BC and the Rockies, even in the heat of the summer, and it is hard to find stations that will fill your car/ truck if you need it. The only two things that I would use propane on are a BBQ and to cool a diesel engine that is tuned. That's my 2cents....
pwall Posted February 10, 2011 Posted February 10, 2011 I looked into that for my '02 YukonXL when I had it. I ended up not doing it. $5k is a lot of fuel. And with the winters, think it's more trouble than it's worth. Unless of course you're driving your truck daily. A lot of taxis here in Ottawa run on propane.
DwayneJ Posted February 10, 2011 Posted February 10, 2011 I had not thought of the cold temp thing. I know here in Wisconsin in winter, my gas grill doesn't work well and my heater for the garage does not work well unless I warm the tank and keep it warm.
BigZed Posted February 11, 2011 Author Posted February 11, 2011 Thanks for the input guys. Seems like the cold weather would be the biggest problem to this idea. Guess I'll stick with good old gasoline.
doverarjim Posted February 11, 2011 Posted February 11, 2011 We did not need it but I saw somewhere a preheater for propane conversions, that warms the propane before it is injected. I know that when we used it on our trucks the milage was about 2/3's of normal gas useage. But when you only get 6 or 7 and you only drop to 4 or 5 it does not make much difference. At that time it took less than two years to pay for the change over, the biggest problem we had was when we ran out of propane and when back to gas the carb gaskets would dry out and then they would leak, don't have any exprence with injected motors.
