Removal Of Oxygen Sensor
olibert
Does somebody know a good trick to remove a frozen oxygen sensor ? I tried to unscrew the left front oxygene sensor on a 5.7L Vortex (Tahoe). I soaked it in Liquid Wrench for several days and warmed it up by keeping the engine running for 5 minutes. I used a breaker bar but the exhaust pipe connected to the exhaust manifold would rather bend than it would losen the sensor. I gave it also a try when it cooled down but with no success.
Thanks for a hint,
Oliver
Propane torch it at the threads. After it's nice & hot, if you could touch it, it would come out by hand. The hotter the better.
Heat up the pipe good by keeping the rpm's at about 2500 for 5 minutes (or carefully with the torch)...then spray the 02 sensor with a product by WURTH called ROST OFF ICE. Cooling the 02 while the pipe is hot should break it free.
Do not touch it with your hand after doing that!
