09 2500 Hd Frt. Bump Stops
Hello,I'll start by saying this site is the best for getting answers to questions about G.M.trucks!
My ? is about a 09 silverado 2500HD ext cab 8ft. bx LTZ, w/9200 gvw trailer pkg., but it does not have the plow prep pkg. . While under the truck to chg. oil I noticed that it's sitting on the frt. bump stops at rest unloaded !
The frt. axel is a 4200# with the 6GK/7GK T-bars, I bought it used from a chevy dealer w/12,000miles are these
NNBS trucks designed to sit that close to the bump stop? Does'nt seem right to me Any info/comments will help!
Thanx in advance Dave :lol::smash:
Focijoe ,thanx for the return post. The t-bars have not been touched,and the truck has'nt beenworked hard,but when it's sitting on level ground with out a load the lower control arms are slightly touching the bump stops. Any one else with some info? Hundreds of users on here some one else must have this conition also? Info ,comments, thoughts will be helpful!!! thanks
Mine sits on the bump stops like yours, but I cranked my bars up 1". I don't know If they were touching the control arms stock. You bought your truck used correct? How can you be sure the torsion bars were not touched? Just wondering.
they're designed to sit within 1/2 an inch or on it
if you notice theres two "steps" to the bumpstop, the larger portion you see is a softer compound which gives you ride quality while the second step is hard to actually stop the suspension. alot of aftermarket lift companys tell you to keep the bumpstop either just barely touching or within half an inch or so, so yes THATS NORMAL!!!!
Hey, ruggedlife
Thanks for the reply on the bump stops! I thought that it would be something to do with ''ride'' because this truck's ride is great . I did not hotice the 2 stage design of the jounce bumper and now it makes sense. I had concernse about this as I will be putting a large Lance camper on it and hittin' the beach and elsewhere this year and thought I might have had a problem. But now sounds o.k. Well I'am looking at some other mods to do and thats one less worrie
Thanks Guys! Dave :cheers::)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
