Body Vs Suspension
I'm toying with the idea of adding a lift and can't really decide which type to go with. Other than price, does anyone have any pro/cons to either? Thanks for the help!
All depends on how big of tires you wanna run. Just a size or 2 bigger, go body lift. Its much cheaper. Any more than that you need suspension lift. Also keep in mind if you go very much of a change on tires you should be looking at regearing front and rear.
Body
Pros: No suspension changes, no parts wearing quicker, no ride change. Easy to install, but time consuming.
Cons: Shows off frame/hitch/spare etc.
Suspension
Pros: More ground clearance. Looks better (IMO)
Cons: If done on the cheap side, will wear out parts faster. Rougher ride.
