Rear View Camera
X-man
I am looking for a rear view camera to hook up to the Bose navigation radio in my 2008 Sierra.
So far, I am considering either the Cubby cam ($399) http://www.cubbycam.com/store/index.php?ma...3fd451c43bdaa7d which I think is the same as the GM unit, or a GM backup Cams system ($170) http://www.gmbackupcams.com/products/. Both come with the new tailgate bezel with camera mount.
I am wondering if the Cubby Cam is worth the extra $230. Does anyone have any experience with either of these?
Thanks
I was actually wondering the same exact thing for my '07 Avalanche. Was looking at Cubby Cam as well but nice to see you found this other cheaper product. Anyone have experiences/recommendations on these two units?? Thanks!
I have no experience of either and without seeing detailed specs can not tell you the difference, but the main difference in back up camera quality is their ability to function in low light and viewing angle, the resolution is not really a factor as it is often higher than the display. However the cheaper one does say it is a 170* wide angle so you will have a large field of vision. I would say that is likely your best best as long as it has the factory style connectors to hook it up.
It would make me a bit leery of a site (cheaper one) that has only had 454 hits. If you scroll to the bottom, you will see their counter.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
