Brakes Grinding Bad
I have an 01 Sierra z71. I went on a long trip yesterday to pick up a quad for my friend, at the beginning of the trip I started hearing a nasty grinding when i was stopping, the last 5-10mph. Really sounds like it was the front right, when i got there the front right had quite a bit of dust compared to the other wheels.
Next day I get Wagner pads and rotors, replaced. The pass side (where im almost positive the noise is coming from) inside pad was more wore, and the pad looked glazed and more wore in the bottom, and the rotor was scarred in the same spot. Pads still had plenty of life though which suprised me.Before I left to the parts store i made sure the caliper piston went back in with no prolem and didn't come back out or anything, it seemed fine. Put it all back together, it makes the same damn noise, and i still swear its coming from the front.
Only does it while braking, noise is only a loud metal on metal grinding in the last few feet. Even if my caliper was ****ing up, you wouldn't think you'd get the sound. It sounds like a backing plate that has been grinding on a rotor for days, it sounds prettty awful. I dont think it is a hub because it only does it while braking it seems
Other observations: The pass side pads seemed to be stuck as shit in the bracket. I had to beat them for a couple minutes to get them out. Lubed the SHIT out of the caliper pins, pad slides and changed the hardware/slides on the bracket, and lubed the shit out of that too. The new pads didn't seem to go in that easy either. The driver side pads after a few seconds seemed to slide back and forth much easier, but maybe thats just because I learned the trick lol. Last thing is i checked if the caliper could slide after i put it together, it did, butt later i did notice the driver side had a lot more play in it. I know the rear discs are bad for going bad, but it really sounds like its the front, but i plan to have someone stick there head out the window to listen lol.
Sorry for being so long winded, just wanted to give you all the details. Is it the caliper??? Only thing really left on that side, but i just cant understand how brand new thermoquiet pads and lifetime rotors can sound like a pad backing plate digging ino a rotor that is almost worn down to the cooling veins, it sounds ****ing BAD.
Thanks for any help/advice. :D
I have had my Granvia 4wd for 6 years now.
There is a bad grinding noise when driving from front n/s wheel which vibrates right into centre.
My local garage replaced n/s hub, but noise only went for a short while.
Anyone know where I can get a Granvia expert to look at this please.
darees03
HELP we love this vehicle
1995 4wd Granvia
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
