Energy Suspension Bushings
On my past 83 Caprice Wagon, I had the entire front end redone with black poly-graphite.  Tightens everything back.  Do the body mounts as well.  I would recommend the poly-graphite versions over the regular, otherwise you'll hear the occasional squeaking.
I had them installed on my '96.  Helped tighten everything up and have more crisp response.  Sway bar bushings should take less than an hour to put in.  Just make sure you lube the bushing held by the U bracket, otherwise it will make a creaking noise. :thumb:
I had mine installed at the local 4x4 shop.  I bought the complete kit that replaces anything on the truck that has a rubber type bushing.  Worked out well, very happy with the results.  I am sure it will prove itself even more as the years go by.  I would recommend them to anyone.
Damian Solomon
    HWN808
    HWN808
  • Who's Online   3 Members, 0 Anonymous, 501 Guests (See full list)
