Where are the door switches located?
I looked in the owner's manual and my Haynes repair manual and can't seem to locate the door switches.  I think they are bad possibly.  My dome won't come on when the door's opened, (it's not the override) and the bell won't chime when I leave my lights on after shutting the truck off and opening the door.  That's the only thing I can think of that would cause both of those things to not operate correctly.  Any other ideas?  I just need to find 'em to see if they are working.   :)
They are actually located inside the door itself.  They are somehow tied into the door handle/rod/latch mechanism.  The only way I know how to check them is to lock your doors,  and lift up on the inside door handle, your interior lights should come on if everything is working.
Are they supposed to on a '95?  I didn't know when they started that feature, but they don't do that.  Now I'll have to figure out how to get to them in order to fix/replace them.  That's a start at least, thanks for the input.  I'll be fine as far as taking the door panel off, but from there on it should be interesting.  hehe.  :)
They are the black buttons that are on the sides of the dash on the 95's. Just took mine apart a couple of weeks ago, the switch on the drivers side quit working, popped it apart cleaned up the contacts and it works fine again. If it is the switch the other door should kick on the lights unless they are both bad?
Yep, you're right man.  I feel like a dumbass now.  :(  I went out to my father-in-law's house today and he helped me locate and remove them.  He's an electrician so he used all his little gadgets and checked to see if it was the switch or the wiring somewhere to them.  They are both bad ironically.  I'm gonna try to find a couple new ones cheap, I dunno how much they are at the dealer, but hopefully not too much.  Thanks for the info doods.  Laters for now.   :jester:
It's all good, I appreciate any/all help I can get.  :chevy:  I replaced them with new ones and it solved the dome light prob, but the lights still don't chime when the door's open.  I just need to figure out where the heck that's at.   ???
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
    • This is going to take allot of Assembly
    • Why do they have the gas 10l80 opening at 145?
