When To Put On Chrome Rims
So I bought myself a new set of 20inch chrome rims and have been itching to get them on my truck (get ugly looking winter tires and rims off). From the looks of it winter is over and there shouldn't be anymore snow coming. I drive mostly highway but, some of the side roads still have sand on them from winter. Should I hold off on putting them on because they may chip or something. I will wax them twice before I put them on but am looking for opinions. When does everyone else generally switch their rims in the spring?
Typically everyone around here waits until April. We normally have a freak snow storm in March, although we have gotten lucky this year.
Ended up bitting the bullet and put them on today because I won't have time in the next two weeks to put them on. I just hope we dont get any more snow. ahah Sorry about the crappy blackberry pic. Ill get some more up when I have time.
Put a good coat of wax on them to get you through the next few weeks. Keep them waxed up and you shouldn't have any problems.
Yup, gotta love Indiana weather. We had 75 degrees here in Jasper 3 days ago. Last night we got 2 inches of snow.
Yep I put a chrome sealant on them and then I put 2 coats of wax on them. I will re-apply the wax in about 3 weeks.
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
