325-50-20 (325/50/20) On Stock 2011 2wd?
cyberpine
Is it just me or is there just a lot more wheel well room in the 2008+ models vs prior years.
I was reading an old post on some other forum and found this pic of some 325/50/20s on a 2000 with 20x8.5 rim. Not sure about the offset, but the owner does have a leveling kit and torsion bar turned down.. I do wonder if he needed both of those mods though.
Looks sweeeet! Luv that stance!!!!!!
Check out the comparison to some other close 20 inch sizes. the 325 is shorter than what come stock in a lot of 20 inch factory rims. My experience is that taller tires bump the arm or torsion (whch can't easily be fixed) but wider tires often rub the inside fender if offset is more positive, or the outside fender if too negative.
I'd hate to make a $3000 mistake so would like to know for sure.
So my question is... can a 2011 Silverado stock 2wd run 325/50/20 on stock rims? or some 20x9 or 8.5 rims.. if so what would be a good offset.
Thanks in advance.
Stock tire height for a 2011 Chevy 1500 with the factory 20s is 31.9". Those 325/50s are taller and way wider.
Mostly I'm researching tires before buying the truck. It seems the wheel wells on the newer chevys is huge. Anybody know exactly where these tires would rub and if some minor cutting might allow safe application.
Thanks.
Actually I think they are worse... You'll never fit 325's on it without some sort of lift and it would be unsafe to put that wide of a tire on a factory rim. It's calling for 9-11.5" wide rim. Besides, guys who put wide ass tires on narrow rims,... it just looks stupid in my opinion. Stock tire size is 31.9" and the 325's are 32.8" so its not shorter either.
its just you, the square wheel wells of the gmt-900 are smaller than the previous years, you need more lift to clear the same size tires as previous years..
And as said the 325 width tire is too wide for the OEM width wheel. I would go with a wider wheel like atleast 9" wheel. The best tire size to run with these trucks is a 305/50/20 and a leveling kit. ANy bigger it will rub, no leveling kit, it will rub..
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
