How often does this happen?
Elwood
Jamie McMurray won his first BGN race 2 weeks after his first WC race.
How often does a driver win a Cup race before winning a Busch race?  I wouldn't think it happens very often, but I don't know.  Anybody else have any idea?
This is the first time I can remember something like this happen.
I do remember that Jimmie Johnson didn't win a BGN race until after it was anounced that he was moving to WC the following year.
But it makes me wonder, how come guys in the BGN (like Randy Lajoie, Mike Mclaughlin just to name a few) never get deals like this?
I read once where Lajoie said he had no desire to move to WC fulltime.  Maybe it's because he's had no offers, I don't know.  :chevy:   Just as well to me, I think he's an a$$ anyway.
Tony Stewart has yet to win a Busch series race....
Think back not too long ago;
Jeff Gordon was not all that big in the NASCAR BGN series, but he sure set WC on fire.
Jimmie Johnson was not all that hot as a BGN driver, either, but look at him now...
About McMurray's win. Do you think it says more about his talent or Ganassi's equipment. If it's the equip. then what does this say about Marlin.
Or do I think to much :cheers:
I think it speaks volumes about both.
Marlin has always run good.  He ran good when he was in the Junior Johnson owned #22 Mawell House Ford, but could just never get the breaks he needed.  He's been a consistent top 10 finisher over the years.
However, it doesn't matter how good the driver is, if the equipment sucks, they lose.  Example: Ken Schrader, who used to consistently finish in the top 10, now his euipment sucks and look where he is.
And good equipment doesn't mean you can win without a decent driver.  Example:  RCr has Robby Gordon and Jeff Green, good euipment $h!tty drivers, very little success.
Another good example of fast tracking to Winston Cup is Kurt Busch. A Roush scout caught Kurt tearing up the track on
Saturday nights and put him in the NCT series. Wow can this kid drive! Have a great one!
    • Yea that's pretty normal to be off a few degrees.  Usually 2-4 degrees from say a weather app or thermometer.
    • I just replaced the ambient air temperature sensor.  Easy as pie. I simply had to remove about 10-12 clips on the plastic cover over the radiator and remove two T-10 torx screws on the hood release lever to liberate the cover (Amazingly, none of the clips broke.  All came out and went back in with zero problems). Once the cover was removed, the temp sensor is easily accessible. The sensor cable snakes through a few guides and can be pulled out for even easier access to the sensor. I was able to work the sensor out of the mounting hole.  There is a red sliding catch on the plug that must be pulled back to disconnect the cable.  The plug was quite tight.  I had to use a screwdriver to pry it out. I plugged in the new sensor ($6.45 from RockAuto), snapped it into the mounting hole and re-snaked the cable. I put the radiator cover back on and reattached the lever arm to the hood release.  All done!     I started up my Suburban.  The temperature read 82 °F. Other thermometers at my house read 80 °F.  Close enough.  It might be reading high as my vehicle was sitting in the sun.
    • Remember when you were 50 and they called you Old Man?
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
