Frame Wax Clean Up
I have to admit this is one of the stranger posts I've ever made and I'm not sure if it belongs in the maintenance thread or not. So, mods feel free to move this wherever it belongs.
This is the fourth GM truck I've owned, and I've done more than my fair share of simple maintenance items on all of them. One of the hassles I've run into in working under the truck is the frame wax coating that easily makes a mess if you get it on your arms/hands, etc. It's usually a bear to get off.
Through an accident I found out something that will make cleanup easier. Johnson's baby oil will dissolve the stuff like magic. Then it will just wash off with soap. Thought I'd share this revelation with others who come out from under their vehicles looking like I often do. I almost bet someone who wanted to paint the frame could use the stuff to dissolve the wax. The wax coating in my opinion is good stuff. I've never had an issue with it other than it being messy.
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
