Evap Vent Valve Solenoid, I Challenge You To Figure This One Out!
Please help; I have a 06 GMC 1500 Sierra 4x4 extended cab truck with a 5.3 engine. A few months ago I removed my vent valve solenoid and cleaned the dirt out of it because I got a P0449 code. Upon removing the solenoid valve as expected it was dirty and when bench tested did not operate, common problem with GM. Before purchasing a new solenoid valve I thought I would try cleaning the old one to possibly get it working again. Once I cleaned the valve it operated fine when bench tested. To keep the dust out of the solenoid valve I relocated the solenoid vent forward up by the transmission using a length of 5/8 heater hose as recommended by a GM bulletin. I cleared the code and everything worked fine (no pending codes detected) for months until now, P0449 is back! I thought the old valve must be sticking again so rather than deal with it again I purchased a new Solenoid valve which bench tested fine. But after I installed the new solenoid I still get the P0449 pending code? I've traced out the wiring and it seems to be fine, I've got 12v back at the connection but the new valve doesn't work when connected? The PMC doesn't seem to be grounding the solenoid valve to command it shut. I believe the connection is always supposed to have 12v and the solenoid valve operates shut when the PMC completes the ground connection, correct? I'm starting to think my PMC is faulty but it seems awful funny when I cleaned and reinstalled the original solenoid valve it worked fine for a few months? What should I do next, any suggestions???
  • 7 months later...
Have the code cleared and drive it for awhile to see if it comes back? When mine went I went to the dealer (I found this forum about 2 weeks too late) and paid $300 for repairs not counting the $700 PCM replacement (jury still out if I needed it). Well this response comes 7 months late but might still help.
When I got that code on an 07 I had, it also said to check the gas cap. In my case, a new gas cap didn't clear the code, but a new evap vent solenoid did.
I ended up with both problems...gas cap was shot as well as the solenoid. I started with the cap, hopeful cheap fix. Cleared one code, other one stayed, replaced solenoid & as was well again.
same thing happened with mine, wound up changing both evap vent solenoid and evap purge solenoid. One by the gas tank and the other one was on drivers side of the intake
    • The BORA 3/8" spacers arrived yesterday along with the extended lug nuts. I got the front wheels changed out today, but was overheated and covered in sweat so bad, I figured getting both front wheels done was a win, and took a cool shower. Hopefully, I'll go out tomorrow morning before it gets into the 80+ temps and do the backs. After getting the first wheel snugged up, I backed out one of the lug nuts then hand turned to count threads. I believe I stopped counting around 12-13, so I think I'm good there.
    • My fullsize truck is averaging over 26mpg so I'm pretty happy with the increased fuel economy targets. When I had my gas Silverado (2020 5.3) it was averaging 21. Again, for a fullsize truck, that's very different from the 12-15 these things used to get 30 years ago.   Whine all you want, increased MPG is a good thing.
    • That is a fair point, and I think an OBD-first proof is probably the right next step. I agree that the value is not the hardware box by itself. The marketable part would be the software: always-on capture, baseline learning, event reduction, system-specific reports, and alerts. Also agreed that if an OBD device is always plugged in and has local storage, it should not miss the event in the same way that a scanner plugged in after the fact would. The only thing I would not want to assume yet is that an ELM327-class device gives all the late-GM data needed at the rate needed. Standard OBD live data, DTCs, freeze frame, Mode 6, VIN, and calibration information are definitely the right starting point. GDS2 also proves that a lot of useful ECM data can be viewed through the DLC without needing a DTC first. The question I need to test is whether the data needed for a useful GM V8 event report is actually available through the DLC, and at a useful sample rate: - misfire counts / roughness by cylinder - AFM/DFM state - oil pressure and oil temperature - fuel trims - voltage / reset context - U-codes and communication events - calibration / software information - whether these are standard PIDs, enhanced DIDs, Mode 6 data, GDS2-only data, or not available So I think the right benchmark is: 1. Build the OBD-only version first. 2. Keep it plugged in and logging locally. 3. Compare it against GDS2 / freeze frame / HP Tuners or another higher-end logger. 4. Measure which parameters are available and at what update rate. 5. Only justify ECM-side hardware if it captures useful evidence the OBD version cannot. So you may be right: the consumer product might simply be an always-plugged-in OBD event recorder with much better reporting. A question for you: when you say ELM327 devices can already deliver all the data needed, do you mean generic OBD Mode 01 data only, or GM enhanced data as well? For a useful GM V8 report, would generic OBD data be enough, or would you expect the tool to include enhanced items like misfire by cylinder, AFM/DFM state, oil pressure/oil temp, U-codes, and calibration information?
    • 87 down as low as $5.14 here... winning!
