Gmt-800 De-badging, De-moulding...
Anybody have any pictures of a GMT-800 without and door moulding or anything. On one side of my truck the pin stripe and door mouldings are faded bad. I'm planning on pricing having them replaced but thinking it won't be cheap. And may have to do both side to get a perfect match. So I'm thinking about just having them removed.
Check out my profile. My truck isn't exactly stock, so it won't be the same as yours will be. I will post some pictures after I wash it tonight.
That truck does look good. It's hard to visualize though because my truck will be stock. How old was the truck when you removed the molding? Did you do it yourself? Was there any marking or scratching on the finish where the molding trim had been there for a while? I'm still considering it.
I know my faded molding has to go. But if I don't want to leave it plain I've been wondering about putting the '03-'06 GMC side molding on. It's basically just like one single chrome blade/spear. I've always like it. Anybody know if that would work?
if you take the molding off the side you will have to be VERY careful not to ding your door. the molding prevents dents and scratches on your door and it works well.
i made an attemp to take my molding off my 2001 silverado and it didnt end well. i could not get the sticky shit off for my LIFE spent almost 2 hours scraping so i finally have up and put the trim back on with double sided 3M tape.
Yeah I thought about trying to tackle it myself but I'm going to see what the dealership body shop guy would charge. He has done a few things for me in the past and his work is top notch.
3M Eraser Wheel. If you have a drill (corded, NOT cordless), it will take you no time at all.
The Eraser Wheel can be bought online, or I found mine at NAPA (they ordered it, took a day or so to get it). Make sure and get the mandrel with it. I did my entire 2500HD with it and it had more than half life left in it.
See youtube video (not mine) of a guy using it.
Mine was a 2003, so it was old gunk. And it came off pretty easy. I did the sides and tailgate.
    contrabombarde
    contrabombarde
  • Who's Online   4 Members, 0 Anonymous, 1,344 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
