Any body out there use a Trail FX bedliner?? They are a "snap in" style instead of the OEM GM one that screws in... Local auto parts place has them pretty cheap..
I had a GM one in my 02 and never had any problems with it, but I dont really want to screw it in to my brand new truck..
For you guys with drop ins.. what kind do you have?
Dont even mention spray-in ones, not really interested...I already weighed out the pros and cons and for the price its not worth it for me..
Thanks..
yes, trail fx are snap in, minus the tailgate piece there are a few screws to run in, but honestly you can do without them, you can even run some double sided tape under if if you really dont want to drill at all. TrailFX is Keystone Automotive's house brand of bedliners, (also make vent visors, bull bars, grill guards, steps, toolboxes, several other things) they're almost always considerably cheaper than any name brand and look identical
Thanks for the reply... That makes sense about them being a house brand, as its hard to find them anywhere online...I did read somewhere that they are made by Penda and its Pendas cheapo line called the Poly...not 100% sure, but its what I read online somewhere.
Do you know if they are any good to use?? Are they really cheap and thin and fit well? or are they kinda sloppy?? They are only $100 at the parts store for it, but if I decide to use it, I dont want it to be a piece of crap either..I was thinking about the Bedrug, but sometimes I haul gravel and rock, and wasnt sure about the durability of it to maybe dent the box if I throw some heavy stuff in there..
I had good luck with the OEM drop in I had in my 02 GMC, but never had an aftermarket one..
Just bought a trailfx liner from a local shop. Looks real nice, fits well, and is nice and thick. I told them not to use any screws, and went and put some double sided tape underneath the tailgate panel, and then on the sides at the back of the bed where the liner touches. The tailgate panel also utilizes your factory bolts for your tailgate handle, so it holds in place well with those and the tape.
I like that it has holes for access to the loops in the bottom sides of the bed to tie stuff down, but I'm sure most plastic liners do as well.
I also added some GM bed rail caps, and the truck looks great.
Attached the only pic I have.
I installed a DualLiner and I am very happy with it. Easy to install and the mat is very sticky to hold everything in place.
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
