2001 Gm Suburban 1500ls 5.3l 238,000mi
01' Suburban 2WD 1500LS 5.3L (238,000mi). Begain to code "Random Misfire"
-New Fuel Filter
-Fuel Pressure checked 38-42psi
-Had injectors professionally cleaned "closed loop cleaner"
Seemded to reduce problem for two months then it all fell apart...
Coded Random Misfire, Bank12 O2 sensor/cat converter low.
-Replaced O2 sensors rear both sides
A screeching begain to develop that sounded like a dry bearing on belt tensioner-
Removed, tested, all tensioners.
Still had squeel with modest acceleration but not at idle.
Misfire got worse- no power now. Will idle and pull off of idle but with no power.
Code only shows random misfire.
noise appears at exhaust manifold of rear-driver side cylinder and nowhere else.
have not taken off valve covers yet.
will do a full compression test tomorrow-
Has the feel of catistrophic valve train failure... Is anyone seeing this in this style engine at this mileage?
My '03 tahoe "only" has 182,000 miles but runs like a top. biggest repair has been a throttle body replacment (at about 175,000 miles) because I kept getting a reduced engine power message on the DIC. It was a bad TPS but on these the TPS and throttle body are one unit. Good luck and please post any progress.
I have seen some camshaft lobes worn down and lifters spun. I was thinking it was in the newer ones though, not sure on an 01. I would carry on with the compression test. That will let you know if anything mechanical is going on.
