only 2 grease fittings on my 2011. Did I miss any?
all I see are the outter tie rod ends. not even the ball joints have grease fittings.
rack and pinion seemed to replace all the linkage in my older trucks......
Assuming the 2011 is the same as my 2009, that would be correct. Only 2 grease fittings.
Just two. Rack and pinion setups do away with all the arms and links and other crap. Enjoy the tighter steering and keep the tie rod zerks greased. :thumbs:
