I see them on LMC Truck, eBay, and other bodyshops that also sell online such as Pershing Autobody. Prices range from $19.99 all the way to $99.99. Any real difference between them as far as material quality and or fitment? Just looking for a decent fix to make it not as much as an eyesore.
Also, just wanted to make sure, the new cab corners can completely fix this right?
Driver's side
Passenger side
I would imagine there is probably some difference in quality but not positive. I had mine replaced with ones from LMC and they seem to be pretty solid.
Do you know if the ones from LMC went over the cab corners, or if the corners had to be cut out and then the LMC corners are welded inplace? From what I've read there seems to be two different kinds of cab corners available.
