Wierd Things - my truck is possesed!
Well, not really...
With 6,000 miles on my 2002 Tahoe Z71, I can say that I love it. Always wanted a Tahoe, and this thing is incredible. But it's done a few wierd things and at this point, my opinion is to just leave well enough alone. Give me your thoughts:
1) Fader control on Stereo reversed - When I turn the knob to the left, the rear stays on. When I turn it to the right, the front stays on. Backwards, but it works and since I only use that feature 1% of the time, I decided to let it be.
2) Fuel gauge was fluky - The other day, driving home with a 1/2 a tank of gas, the fuel gauge dropped to empty and the low fuel light came on. Since I always track my fuel usage with the trip odometer, I knew I was ok. Went to the gas station and filled up, and it's worked fine through the last 3 tanks of gas. Since I monitor my mileage regularly, I decided not to take it in as I had this happen once on an Oldsmobile, and it never happened again.
My logic is this - the truck is new, and yes under warranty, but these issues are so minor that I may get the truck back worse than I gave it to them. I've found that when they start ripping stuff apart fo track down inconsistent problems, it's just never the same.
Anyone agree or had similar experiences?
Bought a used 99 GMC Suburban 5.7 with 34,000 miles.
The engine and drivetrain sounded smooth and quiet.
Steering and suspension seemed right, so done deal.
Got an extended warrenty so dealer could fix any issues.
The problems with GM trucks are the stupid stuff.
My list:
1. Had to send the radio back to fix the clock bcause it kept re-setting to 12 o'clock.
2. Drivers seat loose.
3. Passenger door rattle. Has to go back a second time because it just re-appeared.
4. Rear passenger HVAC fan switch replaced.
5. Intake manifold gaskets leaking. A commmon fix on ALL 5.7L
6. Headlight switch and power window switch replaced.
7. small water pump intake hose is now leaking because they disturbed the pipe nipple when dealer replaced the intake gaskets.
Bottom line is watch for the common problems and use preventive maintenance. The odds are you will experience them too.
Yup, more "pain in the butt" stuff than anything else. The compass has gone into CAL mode twice already too. Again though, no big deal, love the truck!
The 5.7L problems won't exist in the 2002 since he's running a Gen III 5.3L.The electrical problems however, we'll sort out one by one. Have a great one!
    ballencd
    ballencd
  • Who's Online   6 Members, 1 Anonymous, 667 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
