Undercoating / Rust Protection?
gmyeah
I live near NYC in the nj burbs. We had a harsh winter last year. I typically apply rust proof around this time. I garage my truck. I typically will wash it once a week when we have snow. I also have ramps and a hose in my garage and will pressure wash the undercarriage. I have virtually no rust on the underside and it looks as new as the day it drove off the assembly line.
I'm in Ontario Canada, and we get it pretty rough in the winter. My 06 has been sprayed once every fall since new at krown rustproofing and you won't find a spot of rust on my truck. They drill little holes in the rockers, doors, and pillars to spray inside using different spray guns/ nozzles and place grommets in the holes after. They do a wonderful job. $150 shop price. That's my personal preference, I can't complain.
  • 5 years later...
Old thread, but since my previous post I have purchased a '15 Sierra that I did go and have it rustproofed & undercoated at a local Ziebart shop.
After the 1st winter it still looks great, and had taken it in for a check/touch up so it's ready for this winter.
We'll see how it looks in another 8+ years.
I just sold my 2003 silverado 2500 HD without a hint of rust on the body. never had it rust proofed, but I started to spray the frame with FLUID FILM about 5 years ago. Give that stuff a try, its way better than WD-40. When I had connections with a distributer, I bought the stuff by the case.
Did you ever end up rust proofing? If so what did you use? I also live in the Buffalo area
Sent from my Z981 using Tapatalk
    • I just bought one of these.   https://www.topdon.us/collections/diagnostic-tools/products/artidiag-pro   Yeah, it`s got a cable. $250/year after 2 years. Do I want more? Yep. But, I`m not working any more and can`t afford a whirlpool in my tool box.
    • Why don't I have a good scanner? I've always wanted one when I've needed one.   My latest reading says I don't need to do a relearn on the ckp sensor on a 1995 with OBD 1.5. The relearn is prescribed for the later-model 1995's which shipped with actual OBD II when GM completed the transition in prep for the 1996 MY. I need to confirm that. Did you know forums are disappearing? Knuckleheads on Facebook... it's not the same. It's just not.   So, scanners. Again, shooting myself in the foot for having eBayed my Snap On MT2500 "brick" with all the adapters. Not that I couldn't buy another but those are getting quite old, and mine wasn't new enough to work on 2000's vehicles.   Damn it (as I'm scanning my email between paragraphs here). Did you know there's a 2000 Jimmy 2-door on BaT that's ending this morning? It's local. I want it. 14k miles. Absolutely beautiful.   Back to scanners. MT2500's are old. Solus, now that could be a contender. There's a ~2008 Verus with a system error that's basically new in box for cheap. Hmm...I'm not sure about a scanner that runs an archaic version of windows (95 or CE, I can't tell).   I want the ability to reset and rotate TPMS, test individual modules, bleed ABS, electronic parking brake controls for servicing brakes, relearn procedures and other bidirectional controls.   Snap On does an MT2600. It's a new model as of last year, marketed as their "entry" scanner. Entry? Only where $1900 gets you through the doorway plus, I'm guessing, $1000/year if you wish to keep it current. So goes scan tools actually designed for production environments. Want decent products with excellent support, you pay for it.   Everyone is raving about Autels and TopDons and Foxconns and all these newer brands that are selling the $500 "prosumer" scanners for backyard hacks like me. They're tempting...honestly. Updates are cheaper, base prices are remarkably cheaper... And you get to deal with bugs and translation whoopsies and, well, just don't use it on anything expensive, OK? Having a dealer replace an ECU because it needs to be re-imaged after an adventure in scanning is no joke. But I think most people are getting by OK with these units.   eBay on a scratch-and-sniff pro-model oldie, a shiny new TopDon, or???   God dang it, I can't stop looking at this Jimmy. I'm ready! I'll Bring The TRailer! It's beautiful.
    • I removed the OE running boards.  It looked so much better.  I wish I took them off a long time ago.     I had to put something back on for my wife.  I wanted Westin Sure Grip Running Boards but they are very pricey, like $600 plus.  I was going to go with the Ionic 41's like I had on the 2019 Silverado but went with Westin Outlaw Drop Steps instead, about $200 cheaper.  They are sturdy and functional but not super crazy about the look, but it works.
    • It's all a crock of 💩
    • I had a Gen5DIY DRL relocate harness from a 2022 1500 that I saved. I had Gen5DIY modify the harness for my 2024 Silverado 2500. Plug n Play, worked perfectly.    Here's a video I made for the 2022 1500 truck. The install is more or less the same on a 2500.    The harness relocates the DRL tot he top amber turn signal on my 2500.
