Undercoating / Rust Protection?
gmyeah
Not sure if this is the right location to post this on the site...but I hope it is. My wife is planning to buy an Equinox and one of the "tough sells" they give you when you get close to a deal is the "Super Rust Protection" and the "Undercoating". Their take is that GM doesn't apply much of any protection like they use to back in the day because they really loose money on it since not all vehicles need in tt in the country. Not really sure if this is a load or not.....but I'm curious. This offering is from Ziebart which is well known in my neck of the woods. Just curious if it's worth doing it or not? The Undercoating is coating that is fairly thick and protects the undercarriage of your vehicle. The Rust Protection is a sealant that is applied from your windows down. Aside from cost.....do these products have any merit? I have no protection on my 2008 Sierra and it does show a hair of surface rust underneath. I found a little info on the product (see below), but not what it's really made of. Curious what folks do with their trucks /Suvs on this site. Thanks.
Undercoating: Heavy abrasion resistant sealant is guaranteed to protect vehicle’s undercarriage against moisture, chemicals and salt that cause rust. Undercoating service provides corrosion control technology that is applied to all visible underside areas.
Rust Protection: Certified technicians apply the sealant to the under body of the vehicle to completely cover all structural metal. The sealant blocks out air, moisture, and salt to prevent the creation of rust as well as protecting metal from any road abrasions.
my dads been coating his 02 jeep and 94 chevy silvy with wd40 since they were brand new and it still looks like the day he bought them. he buys the industrial cans of wd40 and uses a pump sprayer and coats them every month.
big question i have is where do you live.
northeast......buffalo/rochester/syracuse area. Should have mentioned it before. Actually, i never would consider it unless i was in an area that gets shelled with bad weather. as far as the wd40 in the other response. i'm pretty particular with my vehicles since i work them so much, but i can't imagine hitting it with wd40 every month. little pricey for one as well as spraying in every month.....maybe i'd wash my vehicle a bit more and get the same result.
If you work on your own vehicles makes all the bolts on the bottom a pain in the ass to remove as it coats them. Since you live out in the east though, get it, for the love of god and all thats good, get rust protection, undercoating and diamond kote. Also washing your vehicles a minimum of once a week during the winter is not a bad idea.
With where you live, I would do it. My current truck is the first one I've owned not to get rustproofed. It being a 3500 2wd dually, it has only been in the snow once.
Mark
Read your Owners Manual carefully on rust protection and warranty. GM does not advise undercoating as it retains moisture and salt that cannot be readily washed away.
years ago when i was living on Long Island we used a paint called X-O Rust on our plow trucks. it's not cheap paint, but designed for steel ships. the paint lasted over 7 years before needing a little touch up.. just something to consider..
good luck
I'm in PA and I never get anything rustproofed or undercoated. There is plenty of salt use here. I keep my vehicles in the garage, put low miles on so that helps. The last truck was 9 years old, 60k miles and no body rust.
It's something to consider, but how much do you drive the vehicle, how well do you take care of it, as well as how long do you plan to keep it.
And there are a lot of junk 10-11 year old trucks out there that weren't treated.
Mark
Mark
Generally....the trucks/cars we buy are with the assumption of 10 years of ownership. I should have put in more details in my first post. My opinon is I wouldnt even consider it if I was the average vehicle owner that only kept it for 3-5 yrs....and lived in a warm climate. I'm just the opposite, so the info on this site is good to hear. Thanks. Apparently the rustprooofing they use to put on at the factory has been reduced or eliminated after 2003...need to confirm that though. Either way, I don't think I've ever seen a 8-10 year old vehicle without rust underneath (with or without) the treatment. Of course its hard to compare apples to apples since the treatments and materials have changed as well. Just hoping the treatment preserves it a bit more. Thanks again.
Dont spray the rust protection on already rusted items like brake line or fuel lines,If you do that the chemicals in the rust protection will eat threw the lines no problem.been there done it.
  • 5 months later...
Rustproofing & Undercoating, a good question to get it or not.
I live in Wisconsin, and the road crews love to use road salt during the winter months and now they are also using a liquid de-icer which I feel only adds to the corrosion problems.
With cold temperatures it isn't always practical to run a vehicle through an automatic car wash with the undercarriage spray, but I try to do it when possible.
Rustproofing may be a good idea, not so sure on the undercoating.
Reason I say this is I had my truck, an '06, rustproofed & undercoated when new, but after 5+ years (and only 13k miles) there is noticeable flaking of the undercoating and signs of corrosion on the frame & brackets.
Not sure if the wax coating that GM puts on the frame is good or bad, and if because of that coating, the rustproofing isn't as effective and doesn't adhere well?
Another thought is if one does have a vehicle rustproofed and/or undercoated, maybe have a shop such as Ziebart do it and take it in for yearly inspections & touch-ups.
Just remember, the more they spray and the heavier, the more likely to plug drain holes and hold the water in on body panels. It's probably a catch 22 depending on your situation.
I have 2010 (Silverado, LS 4x4), live in the Buffalo, NY area and I use "Rustop", I have it applied in every July.
The material is thin like an oil, coated and stucks well to the underside (not a waxy material and it kept "leaking" from seam and door panel weeps all summer. It's recommended as a yearly application.
That's my 2 cents.
    • Here's the second UOA on my 22 Wrangler with the Ecodiesel. This has 5k miles on AMSOIL Signature Series DEO 5w-40. The first one was dealer installed oil, no clue what it was, the second is what AMSOIL recommended, European FS 5w-40, Most of the Ecodiesel world is showing great results using the European MS 5w-40, I figured I would see how the DEO works. This is using an Ecoguard oil filter. It's my understanding this engine likes to shed aluminum.  We will see. So far I don't think this is too bad.
    • I'm surprised nobody seems to offer a solution like the start/stop device I put in my new truck. Remembers my setting when shutdown. And while it still starts up in start/stop, it stores/evaluates what mode it was in when shut down and will change it whithin a second or 2 of startup. It'd be nice to have something like that for the DRLs.
    • 2015 Sierra 1500 here. Leaks from the sunroof to front driver side and soaks carpet. How do I fix this? Thanks!
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
