Fast Blinking Left Signal?
Vetts
I have a 2007 Sierra (new body style) and the left turn signal sounds like it's rapidly blinking but none of the left bulbs are actually lighting up. I know this happens when one of the bulbs are burnt out, but they all look fine. Also when I lock/unlock the doors with the keyfob, only the right side blinks. Is there a turn signal flasher that can be replaced? Is it something I can fix or do I have to take it to GM to get them to reset something?
There is no flasher relay, flashing is controlled by the bcm. So either you have a bulb burned out or a loose wire, or a disconnected connector.
The rear turn signal is fed off the front connector at the front lamp so I would start there because if that connector is loose, diconnected, or has a broken wire then the rear won't flash either.
Well I feel stupid. Before I posted, I checked the fuse panel under the hood and the left turn signal fuse was fine. Little did I know, there is another panel on the left side of driver's dash. There is another 15A mini fuse for the left turn signal under there. It was blown. Crisis averted. :) Thanks, Old-chevy-dude anyway! :)
