Alan Harkleroad Posted June 16, 2011 Posted June 16, 2011 I recently replaced the primary headlamp bulbs with Silverstar Ultra H11 bulbs. As recommended by Sylvania as an approved replacement. Now the Daytime Running Light portion of the bulb is not working. Headlamps work if activated manually or light sensitivity sensor. But the DRL portion is not funtional. The main lamps the came out were Philips H11 LL, what went in were Sylvania SU H11's. Same voltage and Peak Wattage at 55W. 12.8 V. So I am confused as to why the functionality would not be the same. Any one else already solve this problem? Or is it just the way it is if not using H11 LL lamps. This is obviously for the low beams. Thank you to anyone who can shed some light on this for me. Alan
