Transmission Temp
I noticed that my transmission temp today was 196 degrees. Is that a ok temp? It was 101 outside today so that might be a contributing factor.
Thats fine. Pretty normal. 225+ is when you should start to worry
as long as it stays under 200, your good. It shouldnt get over that unless you are towing or in the mountains or something. 225 is the point when the fluid will begin to break down.
175*-225* is considered "ideal" operating temps for an automatic tranny.
240*- Atf fluid forms varnishes
260*- Seals harden
295*- clutch plates slip
315*- Seals and clutches burn out and fluid forms carbon
Non towing and cruising, I have found that my trans temp is about 2 times ambient temperature, plus or minus 10%. Unless it is cool, like less than 50 degrees.
So, your temps about right.
Larry
90-100 degrees over ambient temp is normal once fully warmed up and at operating temperature.
DEWPFO
Thanks guys. I was going to replace the fluid but I guess I don't need to. 53,000 mile on the truck. If I do replace it what do you guys recommend as a good fluid? Price doesn't matter to me.
Thanks,
Jason.
