Rancho 4" Lift Problem Nnbs
Wheels are not stopping an inch or two too soon, the lower control arm is hitting the steering knuckle an inch or two too soon and when I turn the wheel to lock it's dropping one side of the truck down because the tires can't turn any more even though the steering wheel is. Definitely a "rolling" feeling though. I wonder if larger rubber would help... Nothing hits on the stock wheel though, plenty of room.
  • Replies 40
If i understand that right i think you just need to stop turning when you get to that point.. Its annoying because you lose a bunch of turning radius, but it happens on almost every lift kit I have ever seen... Parking lots will never be the same!
what is your tire size? I think you'll find most people recommend 33x12.5 with that lift.
Dang that is annoying. Hopefully it won't hurt anything turning past the point of contact as I'm sure I'll end up doing again and again til I get use to it. I just got the stock tires now. 265/65r18, so like 31.5 x 8 or so I think. Saving up for tires, maybe wheels if I have to.
you should be OK with the OEM wheels, just get some 33x12s on there and it will look MUCH nicer and make a world of difference.
Basically your truck now negotiates turns and parking lots like a 2500.
Thanks for all the help everyone! I don't mind the turning radius so much, just wish I didn't have to pay that much attention and be sure I stop turning the wheel early to avoid damage... Something I wish I knew about before putting the lift on.
Yeah, that'd be awesome it wider tires would stop the roll/dip feeling on one side while turning. I don't think it'll damage anything compressing the suspension while turning, but I think I'll take it to like 4wheelparts or something and double check it won't harm stuff until I can afford some tires and maybe wheels if I have to. I like the stock 18's though.
I just did the 4inch rancho lift as well. I had the roll/dip feeling with my truck too with my stock tires. All went away after bigger/widder tire and wheel allignment. Good luck!
  • 4 months later...
***UPDATE***
Figured out the outer edge of the front tires are scrubbing while turning at wheel lock. Hopefully frequent rotations will prevent this from affecting tire life too much. Eventually I'll buy larger and wider tires that I hope solve the noise/scrub problem.
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
