Auto Transmission Jerking
I have a 2000 Chevy that has the all to familiar JERK/Slam when it changes gears.
This is a company truck and we have a 99 that also does the same thing.
I had it serviced and they changed the valve body? (I dont know exactly what because our shop foreman had the work done)
Well now its worse than it was. I drive 10-15 miles and it will start slamming when it shifts. If I pull over shut it off for a few minutes then it shifts good again for another 10-15 miles.  :angry:
It seems like a pressure problem. The most noticable is when im at highway speed and accelerate to pass, It downshifts fine but when I let off of the gas thats when it slams.
Are there any other sites anyone knows of that may have some more info?
Thanks, COZWV
There is a bullitin on the valvebody.  From what I hear GM is on their third design to fix this problem.  Something inside the transmission is causing excessive line pressure.  It could be a blocked accumulator piston but that's highly unlikely.  It could also be the pressure regulator, but that probabbly was replaced when the valve body was replaced.  I can't think of anything else.
I've been thinking about this problem.  It could be the "adapt-shifts" program.  This is a program that when the truck is new and you drive with a heavy foot it will shift harder then someone driving around moreconservativly.  There are two ways I know of to clear the program.  Easiest way is to leave the battery disconnected for a few hours.  This should clear all the info. in the PCM.  The other way is to bring it to your dealer and get them cleared.  They use a diagnostic computer called a Tech 2 to clear the "adapt-shifts" program.
