Rc 1.25 Install Problems
So im in the middle of my rc body lift and im at the part where you put the pucks on the mounts. Anyway, when i lower the body onto the mounts with the pucks none of the bolt holes line up. I cant get any of the cab holes to line up except the very front two behind the grille. Anyone else run into this problem? How can i shift the body a little to line the holes up, there only off by like a 1/4 of an inch.
The trick is before you lower the body all the way down you start the bolts. If the bolts don't line up you can still slide the body some.
i also have this kit installed on my 2011 sierra. i didnt have any problems with the body moving on me beacuse i loosened one side at a time, and removed the other side completely. with the body still off the pucks enough to move them i started all the bolts on one side. lowered the cab, turned the bolts 3/4 of the way in and did the other side. i would get a friend of two and try to move the body over that much to get the holes to line up
Thanks guys, i ended up just having to man handle to body a bit. The little trick with starting the bolts worked great to. Thanks for all the help. Ill be sure to get pics up when im done.
Any pics yet? Wondering how it looks on your rig...
Well im not all the way done yet. I have the front done but havent had time to do the bed yet because of work. Front was a beast to put on, the back shouldnt take me long.
    liddlera
    liddlera
  • Who's Online   6 Members, 1 Anonymous, 391 Guests (See full list)
    • If you have actually done it, there must be some secret tool or method of accessing the hidden bolt head that both manifold connections have. Two of the three bolt heads are staring at you in the face from below but the third one is covered by shielding and as far as I know only accessed by removing part of the fender well lining to gain access to it and even then its awful to access or from what I had seen of someone fighting with it on a video.    There is a reason why even mechanics that deal with the awkward or risky business of undoing the exhaust at the manifolds have done the same method others are doing with these L8T by flexing the exhaust if need be or just able to slip the pan out as I did without needing to touch hardware or pry on the exhaust. By rights the two seals should be replace when those joints are cracked loose as well.
    • Actually it was a lot more controlled then I thought it might be and that isn't actually when I spilled some oil. I had thought prior of rounding up a couple of longer bolts with the same thread to swap out for a couple of the front edge pan bolts and then leaving one bolt left in the back but loosened off and then using a suction device to remove most of the fluid, that certainly would have worked and while I do have a couple of different devices I could have used to suck the fluid, now having done the job once I wouldn't even bother. I had thought of buying one of those pressurized vessels to suck or new fluid in and would if I was doing a job like this on a few vehicles but with one vehicle I just didn't bother and I have pail pumps as well I could have used assuming the hose end would fit into that less than roomy space but being such a thin fluid it pumped well with a quart type pump and just kept the hose into the trans and kept swapping containers and repeat.    What I would change to the method I did though was first jack up just the rear of the truck to put on jack stands to allow more oil to come out of the check plug on the front of the pan ( and as I did, I made sure to put that drain plug back in finger tight ) then follow through by putting the front on jack stands. Also that I would have used a larger sized drain pan in the sense of covering an area wider/longer beyond the transmission but I didn't have one and saw someone else on a youtube video using a masonry mud mixing tub and bought one at a hardware store to use in the future. The main oopsy  I did and why I spilled some oil was all my fault as I neglected to follow my own plan, I should have let down the pan as I did to drain out the front of it as much as would come out but then scooped out the remainder of the oil with the Dixie cup I had sitting there just for that purpose as by that point there is enough room to reach right into the front of the pan and just bail it out basically.
    • Pretty easy to just remove/drop the exhaust behind the manifolds. They're in no way hard to get to. Maybe 5min of work, and you get the opportunity to put some anti-sieze on them in case anything ever comes up, you eliminated the risk of snapping a stud.
    • I let the dealer do every other oil change simply so they can rotate the tires, which is a pita at home.
    • I addition, I won't have a pan full of fluid sloshing around to get all over the place.   I am putting on the Dorman pan with the drain plug. It looks like it is around the same height. I have one of these guys to make life a lot easier.   https://www.amazon.com/dp/B09CDXJCCT?ref=fed_asin_title&th=1
