How Do People Sell Stuff Cheap On Ebay?
tyhuck
I decided to gather all of my stuff that I dont need anymore together and try to get rid of it. I put a few things on ebay, and after selling my first item, I realized that may have not been the best option. It is the most likely place to sell these odds and ends, but almost 20% of the money I made went to fees to ebay and Paypal.
Because of that, I have to make my prices kinda high. Is there a secret that Im missing that allows people to sell stuff cheap? Or, more importantly, how can I reduce my fees payed in?
I first hit the forums to sell, and craigslist..
Selling on ebay sucks because of the fees, but if you cant sell local or on the forums, the exposure u get on ebay cant be beat.
One trick to selling on forums , if the buyer is paying you through paypal. Have them pay as a personal transaction or gift. Paypal dosent charge fees for gifts..
But, it is a risk for the buyer.. So a lot of times people think twice about paying like that.
+15 on craigslist. I have bought a few things and sold a few things. Even sold our 2000 impala on there.
    rayredbone
    rayredbone
  • Who's Online   2 Members, 0 Anonymous, 479 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
