DONT LET GM BRUSH US OFF....
[:angry:]   I took my car to the dealer for the knocking and the shopfore man said yes there was knocking and there is nothing they can do about it to correct it because there isnt a fix. When I was at the dealer there were 5 other trucks with the same complaint. He says that GM will respond to the problem and correct it if enough people bitch about it. The service manager said complain to the chevy marketing dept. and say that they can not advertise "Like a Rock" when it has a bounch of rattles!  He has a 5.3 and it does the same thing. I think GM is brush us off and saying that the knocking is normal. Here is a number to complain to, Vic Smith he is suppose to be the UAW quality network rep for Gm phone # is 608-756-7336 or fax 608-756-7569
check out these Consumer Complaints from NHTSA.(silverado-engline)
http://www.nhtsa.dot.gov/cars....Vehicle
Consumer Complaints
8 Record(s) found
Check to order research. Submit below.
ODI ID: 759496 Make: CHEVROLET TRUCK Model: SILVERADO Year: 2002
Incident: No
Fire: No
Number of Injuries: 0
Date of Failure: 11/10/2001
Component: ENGINE
Summary: ENGINE MAKES LOUD "TICKING" NOISE WHEN WARM AT IDLE. GM STATES NORMAL CONDITION. NOT ALL DURAMAX DEISELS MAKE THIS NOISE. IT CANNOT BE NORMAL. GM HAS NO INTEREST IN PURSUING. ALTHOUGH THIS MAY NOT BE A SAFETY ISSUE, UNLESS THE ENGINE EXPLODES AS A RESULT, IT STILL IS VERY DISHEARTENING THAT GM WILL RELEASE THE PRODUCT WITH BUGS AND THE CUSTOMER IS FORCED TO ACCEPT.*AK
ODI ID: 763757 Make: CHEVROLET TRUCK Model: SILVERADO Year: 2002
Incident: No
Fire: No
Date of Failure: 04/18/2002
Component: ENGINE
Summary: THERE HAVE BEEN REPAIR ATTEMPTS NONE HAVE BEEN FULLY SUCESSFUL. NO SAFETY DEFECT LISTED. *AK
ODI ID: 763947 Make: CHEVROLET TRUCK Model: SILVERADO Year: 2002
Incident: No
Fire: No
Date of Failure: 06/27/2002
Component: ENGINE
Summary: NO SUMMARY LISTED FOR ABOVE VEHICLE. *AK
ODI ID: 8002354 Make: CHEVROLET TRUCK Model: SILVERADO Year: 2002
Incident: No
Fire: No
Date of Failure: 01/09/2002
Component: ENGINE
Summary: ONGOING TICKING NOISE IN 5.3L V8 ENGINE WHILE RUNNING. DEALER NOTIFIED. FEEL FREE TO PROFVIDE ANY FURTHER INFORMATION.*AK
ODI ID: 8006810 Make: CHEVROLET TRUCK Model: SILVERADO Year: 2002
Incident: No
Fire: No
Date of Failure: 03/28/2002
Component: ENGINE
Summary: VEHICLE STALLED AT 70 MPH, VEHICLE IS AT DEALERSHIP AT THIS TIME.*AK
ODI ID: 8008364 Make: CHEVROLET TRUCK Model: SILVERADO Year: 2002
Incident: No
Fire: No
Date of Failure:
Component: ENGINE
Summary: ENGINE HAS A COLD KNOCK WHEN STARTING UP IN MORNINGS, ALSO GMC HAS ACKNOWLEDGED THE PROBLEM. IT'S A CHARACTERISTIC DESIGN IN VEHICLE.*AK *TT
ODI ID: 8017861 Make: CHEVROLET TRUCK Model: SILVERADO Year: 2002
Incident: No
Fire: No
Date of Failure: 07/04/2002
Component: ENGINE:PISTON RINGS
Summary: WHEN STARTING THE VEHICLE, THERE IS A KNOCKING NOISE COMING FROM THE ENGINE CAUSED BY PISTON SLAP, IF NOT FIXED, THIS COULD CAUSE PISTON TO BREAK AND DAMAGE THE ENGINE.*AK CONSUMER IS CONCERNED THAT THE ENGINE WILL FAIL IN THE FUTURE. *YH
ODI ID: 8022008 Make: CHEVROLET TRUCK Model: SILVERADO Year: 2002
Incident: No
Fire: No
Date of Failure: 09/05/2002
Component: ENGINE
Summary: DURAMAX ENGINE, THE ENGINE WAS TICKING WHEN VEHICLE WAS PURCHASED (600 MILES), DEALER STATED THIS WAS NORMAL. THIS TICKING SOUND HAS GOTTEN WORSE, DEALER STILL SAYS THIS IS NORMAL.
After reading that fill out the complain form. The more complaints maybe someone from GM will wake up!
http://www.nhtsa.dot.gov/cars/problems/ivo...OQ/VOQ/voq1.cfm
Thanks guys!
see   ya could have did it the smart way and posted this in a reply one one of the hundred threads already going about this nonsense but you had to start another thread..  not a smart move, when it's already been posted a thousand times, over and over  that they are not going to do anything and that it WILL NOT HURT THE ENGINE!!!
Johnnie aka "Mr. Johnnie" Cochran may be "the man" for the job.
"If you hear a knock or a clack, GM must take it back!" ;)
 Be advised, product liability lawyers require steep retainers, in some cases. Mr. Johnnie is not one, but he will play one for the right amount of money. Without proof of catastrophic failure or injuries-(multiple and serious)-not much incentive exists for "good hearted" repair expenses. Risk vs benefit is the deciding factor. What does GM risk by not fixing, what risk exists to their profits by not fixing or fixing, what benefits do they reap by fixing, what costs less and means more profit in the long run?  Do they stand to lose a lawsuit or not and if they lost, how much could it be? No one has stepped up to test it in court. Since there are no injuries or deaths reported or even engine failures, a lawyer will probably tell you that your chances are nil.
I wish those who have the problem could get an easy and satisfactory fix, but the reality is that it's not likely.
Have to agree with the Doc here.
#1) Most lemon laws say it must affect safety, value or use to be a lemon item.
The problem is categorizing it too.  I would hate to see GM blow off the man with a serious KNOCKING ENGINE, by calling it cold start knock (which I call a tap).
I guess if there was a decibel and a time limit E.G.
"If your knock exceeds X decibels over a 90 second period"
Then you have a bad crank or a piston problem.
"If your knock is less than X decibels, for less than 90 seconds and occurs when you start the motor cold...."
Then you have an acceptable level of knock.
"If your knock continues beyond 90 seconds and registers X decibels.....then you have a diesel engine or deserve a new gasoline engine that does not knock....or a $2500 check and a set of earplugs whichever you choose.
Most of us know what a valve train with improper oil flow sounds like.  Most of us can tell the difference between "The oil hasn't gotten up to the top of the motor yet" and "A clogged up pushrod that is starving the top end for oil."
The unfortunate thing is that when it is a widespread problem....it becomes polar, black and white.  All knock is categorized as acceptable when it maybe should not be.
Hello,
To all the piston slap suffers out there....
if you do have a complaint of piston slap that goes away when warm and if the cylinders are canceled and the noise changes? this is in FACT due to the to short and to thin piston skirts used to reduce weight and increase fuel mileage with the pistons that GM installed .
As of now, if you take your 4.8, 5.3 or 6.0 L truck into the Dealer and the Service Manager knows what he is doing, you WILL get this repaired... 1st you need to call GM customer assistance and set up a case, then you will get a 100,000 mile extended warranty. Then if the Service manager calls the dealer rep, you can and will be able to get the following ASAP:
the 4.8L and the 5.3L pistons and a new crank ARE AVAILABLE
the 6.0L engine, you will get a NEW ENGINE!!!
As for excessive oil consumption GM calls excessive oil consumption is the use of more than 1qt in 2000 miles in the 4.8L , 5.3L engines . if your 4.8 or 5.3 is using excessive oil, 1st you probably need a new style orifice PCV valve and the valve cover inspected and possibly new lifters depending upon when it was built and the engine size.
Unless you have the 8.1 Liter engine. which states " the use of more than 1qt in 100 gallons of fuel used is excessive"
and on this engine. then the intake bolts and intake gasket would have to be replaced if it is actually using too much oil.
Hope this clears things up for all you GM Owners and this is 100% ligit!!!!!!
GM ASE Master Certified Technician
Back to top
:jester:  :seeya:
:jester:  :seeya:
Quick question- If I don't have excessive oil consumption
or knock in my 2001 5.3 than should I still have replaced
my pcv valve with the new type(no guts)?  I did get a 100k
powertrain warranty by bitchin about my driveline clunk so
if I start gettin the knock I'm all good (I hope).
Thanks!  :(
Just a friendly Mod note:
DO NOT go by everything this guy says until there is proof that he is in fact a GM Tech.
Thank you
Thank you
Well put Larry.
For every ones information:  This board can not substantiate these claims until we can confirm a TSB# or hear otherwise from GM. Please do not go to your dealer and start ranting and raving saying "It's true because I saw it on GM-Trucks".
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
