I Need Help Deciding On Wheels/tires
Banshee8732
I've got an '11 Silverado CCSB 4x4 with factory wheels/tires on it- 265/65R18s (18x8.5). I don't have a leveling kit.
I don't know what I should do. I've got a few choices I'm playing around with.
1. Buy aftermarket wheels/tires, 265/65R18. All of the wheels I'm considering are 18x9. How are 265/65s going to look on an 18x9? I love my factory set up, but those are on 18x8.5s
2. Buy 275/55 tires and put them on 20x9s. The 275/55/R20 is a factory option, but I'm not sure how wide the factory 20s are.
I've found a set of wheels/tires in the 265/65R18 I really like, but again, they're 18x9.
Ah I don't know what to do, this should be fun but it's getting frustrating.
Factory 18 are 8 inches wide
Factory 20 are 8.5 inches wide
If you are going to run small tires then stay with factory wheels. If you want 20s find some stock ones for your truck.
What he said.
Alright, factory 20's are 8.5. Everything else aside, if I put 275/55/20s on 20x9s +18 offset, will they fit or will that extra 1/2" cause them to rub? (without a leveling kit)
I'd like a leveling kit; I had a 2.5" leveling kit on my 04 Silverado and 33's. I ended up having to replace different things on the front end. Coincidence, possible, but I'm leery of it happening on my new truck.
Ya that happens to all these trucks anyhow.. I would do a 1.5" level kit, 2.5" is too much.
Hmm. Well, if I don't get a lift kit, will I be able to fit 275/55/20s (20x9 +18mm offset) ?
    Greg3160
    Greg3160
  • Who's Online   4 Members, 0 Anonymous, 870 Guests (See full list)
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
    • Im in the same boat. Carlink adapter comes tomorrow and dev account is in process. Would you he able to send the new instructions my way also? Question, do you have to change code and republish app everytime developer updates? Thanks for your assistance, truly the only thing i cant stand about my truck is the carplay limitation
    • Parts department or service department at the dealer.
    • I’ll take the blue one!
    • And Google AI says......... Yes, your truck can technically handle it, but you will be right at or near its maximum limit. A 2016 Chevrolet Silverado 1500 High Country with a 6.5-foot bed has a maximum payload capacity of approximately 1,770 pounds.Weight RealitiesLoad weight: Half a cord of dry hardwood weighs roughly 1,100 to 1,500 pounds depending on the wood type (like oak or hickory).Payload limit: Payload includes the weight of the wood, you, any passengers, and a full tank of gas.The math: If you weigh 200 pounds and have a full tank of gas, a 1,500-pound load of wood puts you right at that 1,770-pound ceiling.Safety TipsCheck the yellow and white sticker on your driver-side door jamb for your truck's exact payload number, as high-end luxury trims with extra features have slightly lower capacities than basic trucks.Expect the rear end to sag noticeably.Drive carefully, avoid sudden turns or stops, and keep speeds low if you have to travel a distance.
